Water Pump Wheeping
Water Pump Wheeping
I was pouring in coolant for the first time in my new engine tonight. I was getting all giddy, ready to fire her up, but then the coolant just came right out of the wheep holes in the water pump. The water pump was used on the old engine, but I replaced both gaskets using RTV sealant. I don't see why it would start now, and not before. Am I just missing something here?
When I put in the new 300-6 in mine back in Feb, it looked like the water pump also but after carefully following the water trail it turned out that we did'ntscrape the thermostat housing off good enough and some gaskett was left.Check that and your
block for left over gaskett where the pump bolts on.
Alway wise to install a new or rebuilt water pump, when an engine is replaced. Overheating a remanufactured engine will void shop/factory warranty. Also a good idea to fill system with water only at first, to make sure there aren't any leaks in the system. Allow engine to cool down completely, pull lower hose to drain, reconnect, top off with coolant.
The engine shop that rebuilt my 5.8L, installed a "dime sized" heat sensor, in the center of each new freeze plug, located at the back of both heads. If "sensors" are damaged, shop will know engine was overheated. The owner didn't tell me about the sensors, I just noticed them when reinstalling the engine. Engine has a one year, unlimited mileage warranty. Void if engine is operated when low on oil, or overheated ... common sense! He recommended oil be changed after the first 500 miles, every 3,000 miles "max" thereafter, for long engine life.
