replacing freeze plugs - Ford Truck Enthusiasts Forums
Old 10-15-2002, 11:11 PM
ackusackus ackusackus is offline
ackusackus is starting off with a positive reputation.
While replacing my alternator, I discovered I have a couple of freeze plugs that are rotting and starting to leak when the engine is cold. They are on a 77 2wd w/460, and luckily it is not the ones right next to the mounts.
How do I get the old ones out and new ones in? I fear the old ones do not have much longer, they have the cancer and the corrosion is pretty deep.
thanks once again.
ackusackus
Old 10-16-2002, 08:21 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Think about biting the bullet and replacing all of the freeze plugs. Chances are if one is bad many others are too. Replace your coolant more often in the future, the corrosion inhibitors do become depleted. If your coolant is clean you can buy replacement inhibitor at the parts store.
Drain the cooling system and the block. Save the coolant for re-use if possible. Dump it down the toilet if it is all used up. The sewer plant bugs just love antifreeze, they thrive on it. Clean up any spills and wash them down with water to keep animals from drinking it.
Knock the plug out with a screwdriver or punch. Clean the block surfaces and remove as much crud as you can from the water passages. Put a SMALL amount of Permatex Aviation Form-a-Gasket on the surface and the plug edge. Drive a new plug back in with a large socket or a flat plate. Clean off the excess sealer.
Old 10-16-2002, 11:34 AM
theonlybull theonlybull is offline
theonlybull is starting off with a positive reputation.
another way to remove the frost plugs and not loose them in the block, is to drill a hole just big enough for about a 5/16 self taping sheet metal screw, then screw the screw in, put tension on it with a pry bar, they using a punch, drive one edge inwards, this should disloge the plug, and alowe you to remove it.
Old 10-16-2002, 09:23 PM
very cool, thanks for the info...I kinda figured that was what it was going to entail. but I wanted to check with the pros first.
The 2 beside the motor mount look peachy, practically new...its the 2 in front of it that look like warmed over cow poo.
How many freeze plugs are on the 460 any way?
I have a leak that just sprung today that is actually dripping off the fuel pump...is there a plug up by that? I did not trace beyond that....
thanks
ackus
Old 10-16-2002, 09:56 PM
Mike W's Avatar
Mike W Mike W is offline
Mike W is starting off with a positive reputation.
Freeze plug locations on 460 mjpower76 1987 - 1996 F150 & Larger F-Series Trucks 1 01-19-2014 12:14 AM
390 freeze plugs Lukeydukey1 1967 - 1972 F-100 & Larger F-Series Trucks 26 12-22-2012 10:13 PM
Freeze plugs sizes? finneys98xj Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 01-30-2011 09:09 AM
throttle body freeze plugs leaking szealuss 1987 - 1996 F150 & Larger F-Series Trucks 0 10-17-2010 11:40 AM
How hard is it to change the freeze plug? DJdemon6696 1987 - 1996 F150 & Larger F-Series Trucks 11 04-09-2007 03:21 PM
Tags
2001, 2002, 460, 4x4, change, f150, ford, freez, freeze, location, plug, plugs, replace, replacement, replacing, reuse
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
