2000 f-150 instrument cluster question
i have a 2000 ford F-150 with a 4.2 liter v6 in it with 104,000 miles on it. it did not come with a tach in it from the factory and it is a 5 speed. ford sells new instrument clusters with a tach for about $250. when you buy one of these do you plug it in and does it work, or do you have to do some re-wiring? also, what controls the digital odometer? do you have to re-program those? if anyone out there knows about doing this or has done this i would appreciate the information. thanks!
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Not sure about 2000, but your dealer will probably have to program it to mate with the computer and theft deterent system. It will also have to be set with the vehicle's current mileage. I believe this has to be done by the factory. It is against Federal law to not set this or to set it inaccurately. It would not surprise me if these costs doubled the price of your tachometer.
The RPM signal is probably present, however, as part of their cost engineering, Ford has been removing unnecessary wiring, so it may not be. In the past, vehicles were always wired for available options, but increasingly I find they aren't.
desperado_18_2000
10-31-2005 12:59 PM
tenderfoot55
03-04-2005 12:49 PM
