Cannot lock doors with engine running??
I have a keypad on my door, and sometimes i like to leave the truck RUNNING and get out and lock the doors to keep the AC on for the dog for short periods. However, when it is running, if i lock the doors, the drivers side almost IMMEDIATELY unlocks so i cannot lock my keys inside the vehicle.
Is this a normal feature of the TRUCK or my recently installed alarm system. How can i disable this either way??
Your truck must be equipped with the Smart Lock feature, which operates just as you described. The owner's manual says you can override this feature by 1.) using the manual lock button on the door, 2.) locking the driver's door with a key, or 3.) using the button on the remote entry transmitter
When you are standing outside of the truck with the door open, press the electric lock button on the inside. It will lock all of the doors. Then, immediately after you do that, pull out on the outside door handle of the door that is still open. Close the door while you still have the handle pulled out. All of the doors will remain locked.
Greatcarsx4
11-30-2014 10:59 PM
rc3
1999 to 2016 Super Duty
16
12-02-2007 09:10 AM
