Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-06-2005, 07:33 PM
gtspowerstroke gtspowerstroke is offline
Garage is empty, add now
gtspowerstroke is starting off with a positive reputation.
Generator inop
I have a very detailed understanding of Alternator systems and how they work but this old Generator with mechanical regulator thing is new to me. I have a '62 Falcon Ranchero and the Gen. light is on. It started comming on on start up then going out shortly after(longer than normal to check the bulb works). Then it started comming on and not going off until you rev it a little. Now it just stays on all the time. I've cleaned the points contacts in the regulator but I really don't understand how the system works so that I can accurately diog the problem. Does the two wires going into the side of the generator charge a field coil like in an alternator? So if I full field it will it charge at full. Or I am thinking backwards on this one? How does the current flow through the regulator? Does it dump excess to ground or does it adjust the voltage to the field coil like on an alternator? I need to get this thing working A.S.A.P. because it is my only transportation now that my PSD threw a rod though the side of the block. All help is greatly appriciated.
  #2 (permalink)
Old 08-07-2005, 08:49 PM
Gary B Gary B is offline
Gary B is starting off with a positive reputation.
disconnect regulator conn. you will see three wires together and a forth one seperated. to full field it, jumper the first and third wires together. if it charges then the reg. is bad.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
