Manifold heater 7.3L
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
It is exactly what it says. There is a big heating element in the middle of the five way manifold on top of the motor. You might need to worry about it. If it just quit working it's no big deal, you don't need it anyways....but if the element is crumbling/breaking apart then the chance exists that it could push it's way into the engine.
Several of us have simply removed the heater and the wiring for it and installed a plug in it's place.
Originally Posted by Orezona
Does it serve enough purpose to leave in until it kicks the bucket?
"To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated: "
-ambient temperature must be below 0 deg C (32 deg F)
-engine oil temperature must be below 55 deg C (131 deg F)
-vehicle power must be between 11.8 and 15 volts
-parking brake must be applied on manual transmission vehicles
-the transmission must be on park or neutral on automatic transmission vehicles
-glow plugs must be off
I think it's completely useless, and it blocks approximatey 20% of the arflow through the manifold. Can't say that I've ever missed it in four years of running without it.
Originally Posted by cookie88
Here's an excerpt from the service manual describing it's operation.
Originally Posted by Merkurizer
Hi,
I have a 2000 F350 7.3 Diesel and mostly loving it (till I have to fix something).
I am getting a DTC code PO-0541 - Manf Intake Air Heater Circ Low. What is this and do I need to worry about it?
Thanks,
Merk
Thanks,
Merk
Papawheelie
30
02-23-2017 05:14 AM
bismic
08-10-2015 10:35 AM
RANGER589
18
06-03-2011 10:03 AM
rockher_man
17
08-07-2009 10:11 PM
