00 "X" won't start back up after shutting it off!!
Hello,
My 00 X (v10) won't start after I drive it and shut it off. Turn the key and nothing, no noise, not trying just dead. It's been hot here 90's. It happened the other day and after about 5 mins. of waiting it started up again, but today I had to have it towed to the dealer, and they can't figure it out.....I did a search and saw some similar threads talking about cam positon sensor, neutral safety switch, IAC. Has any one had this problem? 60,000 miles on it. Help.....
Obviously something is getting hot and once it cools a bit it will crank/start.
Since everything else works (meaning the battery is good) I would suspect a bad starter or solenoid first. Just hard to bench test on at the same temp as it would be sitting that close to the engine and exhaust.
Khannink
12-03-2013 08:04 PM
