1997 F350 7.3 L PS towing capacity? - Ford Truck Enthusiasts Forums
Old 08-04-2005, 09:53 PM
robandrhonda robandrhonda is offline
robandrhonda is starting off with a positive reputation.
I am about to purchase a 97 f-350 w/ 7.3 ps diesel. Never had one before. I am buying to replace my 88 chev with a 454 v8 gas. Can anyone tell me what the towing capacity of the 97 truck is? I am wanting to tow my 9000Lb 5th wheel and possibly anothe 3000+lb trailer in tandem. Will the 7.3 handle the load?
Thanks in advance.
Old 08-04-2005, 10:03 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcome to the site
Maybe post this question in the Truck forum or the 7.3L engine forum
Then come back here & introduce yourself or just edit your thread to an introduction.
Old 08-04-2005, 10:56 PM
Ok Thanks! I'm new so I didn't notice the heading.
I'll repost.
Old 08-05-2005, 07:01 AM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
Thread moved to Super Duty forum.
-Matt
Old 08-05-2005, 02:42 PM
G-Bone G-Bone is offline
G-Bone is starting off with a positive reputation.
Check out www.trailerlife.com.
they have a complete list of tow ratings for all trucks.
Very informative.
G
Old 08-05-2005, 07:30 PM
captchas captchas is offline
Guest
captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.captchas has a great reputation on FTE.
Quote:
Thanks in advance.
welcome to FTE the best ford truck site on the web.please take some time to read our guide lines and each areas read firsts to help guide you properly though our site
Old 08-05-2005, 07:50 PM
Stroker_Deezel's Avatar
Stroker_Deezel Stroker_Deezel is offline
Stroker_Deezel is gaining momentum as a positive member of FTE.Stroker_Deezel is gaining momentum as a positive member of FTE.
give us a little more about the truck, but i dont think 12K pounds would hurt it, i think it is right at its rated compacity
Old 08-05-2005, 08:31 PM
Lead_Foot's Avatar
Lead_Foot Lead_Foot is offline
Lead_Foot is starting off with a positive reputation.
my 87 460/c6/4x4/4.10 would handle that load no sweat, im sure the diesel should do the job.
Old 09-05-2006, 12:16 AM
DPorter DPorter is offline
DPorter is gaining momentum as a positive member of FTE.
The 97 can handle the load. Both of my 97's could haul that kind of load. Bobcat on trailer about 10,000 lbs. If this is an automatic the addition of tranny cooler and trans temp gauge is a must for the health of the e4od tranny. Along with trailer brake controler of course.
Old 09-05-2006, 07:01 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD DAVID'S97F250HD is offline
DAVID'S97F250HD is starting off with a positive reputation.
97F350 if I recall with 3.55's were rated for 17500lbs CGVW, I should look for my owners manual
Old 09-05-2006, 07:23 PM
1997F-350's Avatar
1997F-350 1997F-350 is offline
1997F-350 is gaining momentum as a positive member of FTE.1997F-350 is gaining momentum as a positive member of FTE.
it all depends on:
4x4 or 4x2
5 speed or auto
3.55 or 4.10
drw or srw
Old 09-05-2006, 07:27 PM
jimkidd's Avatar
jimkidd jimkidd is offline
jimkidd is gaining momentum as a positive member of FTE.jimkidd is gaining momentum as a positive member of FTE.
Don't tell the DOT man but I've towed over 25,000# on a goose neck with no problems. `95 1 ton PowerStroke.
jimbo
Old 09-05-2006, 07:34 PM
From owner's manual: 1997 F-250 HD, F-350, and F- Super Duty.
Regular cab- 7.3 diesel 3.55 rear- 16000 lbs (10100 trailer weight)
4.10 rear 20000 lbs (14000 trailer weight).
yeah, everything depends from wheel base to 4x4 or 4x2, need more info
Old 09-05-2006, 09:08 PM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
hmmm i had 26k beind mine today!! 8000lb trailer and 18 round bales
Old 09-06-2006, 10:40 AM
Quote:
I've put 5500lbs on my 87 nissan 1/4ton truck in sandbags stacked over the cab onto the roof from the box, drove around my yard fine.
Just cause you can do it, does not mean its safe, espeacialy when the family will be with riding in the truck
anyone running semi super singles on rear? kengarchow 1999 to 2016 Super Duty 23 02-20-2016 07:24 PM
Can I Increase The Towing Capacity For A 2010 F-150 shawnzybear2012 2009 - 2014 F150 16 02-19-2015 05:52 AM
Towing: How much can i legally tow with a CA Class C license? Knewstroke97 1994.5 - 1997 7.3L Power Stroke Diesel 12 02-05-2015 10:38 AM
1997 F350 DRW 7.3 Towing Capacity - bumper and 5th wheel - help ottomandan 1994.5 - 1997 7.3L Power Stroke Diesel 16 05-02-2013 10:12 PM
towing capacity of F250 ohmar99 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 33 12-28-2012 09:58 PM
Tags
1997, 73, 97, capacity, diesel, f250, f350, ford, hd, power, powerstroke, specs, stroke, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
