1997 F350 7.3 L PS towing capacity? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-07-2006, 07:19 AM
barebackjake's Avatar
barebackjake barebackjake is offline
barebackjake is starting off with a positive reputation.
i would have liked to see that one david!!
yeah that much wieght not over 45mph, just takes a bit to stop. round here during hay season its pretty common to see 1 tons runnin around with 20-30k behind them
17k gcwr is about max safely
Old 09-07-2006, 09:29 AM
jimkidd's Avatar
jimkidd jimkidd is offline
jimkidd is gaining momentum as a positive member of FTE.jimkidd is gaining momentum as a positive member of FTE.
And... good trailer brakes are a must!
jimbo
Old 05-23-2014, 12:01 AM
Knewstroke97 Knewstroke97 is offline
Knewstroke97 is starting off with a positive reputation.
Anyone ever found a definate answer from the factory for this truck's tow limit? (F-350 7.3L CCLB SRW) I have the same truck.
Old 05-23-2014, 09:59 AM
nossliw's Avatar
nossliw nossliw is online now
nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.
Quote:
It was linked in the previous page, just have to put a little effort into looking for it...all 20 seconds of effort :-)
http://www.trailerlife.com/wp-conten...Guide-1999.pdf
Like others have mentioned these trucks will tow damn near anything, yeah they are not DOT approved to 30,000lbs like a 2015 dodge, but I bet they could pull it..... stop it, absolutely not :-) Take heed on getting a good tranny cooler and a set of guages are very beneficial. Hope the link helps, yes it was for the 99SD but its identical for the 97 to a couple hundred lbs. I tow 12-14k gooseneck weekly without an issue, truck will stop it just fine too. Disk braked read SDs do stop much smoother, but if you have your rear drums adjusted properly you would be surprised how quick ours will stop as well.
Good luck
Old 05-24-2014, 01:51 PM
Yeah I saw the '99 SD Tow Guide. Was looking for official Literature. Let me know if you come across anything.
Old 05-26-2014, 11:43 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
I stop my 18K 'train' just fine. I do have disk brakes on the 5er though.
anyone running semi super singles on rear? kengarchow 1999 to 2016 Super Duty 23 02-20-2016 07:24 PM
Can I Increase The Towing Capacity For A 2010 F-150 shawnzybear2012 2009 - 2014 F150 16 02-19-2015 05:52 AM
Towing: How much can i legally tow with a CA Class C license? Knewstroke97 1994.5 - 1997 7.3L Power Stroke Diesel 12 02-05-2015 10:38 AM
1997 F350 DRW 7.3 Towing Capacity - bumper and 5th wheel - help ottomandan 1994.5 - 1997 7.3L Power Stroke Diesel 16 05-02-2013 10:12 PM
towing capacity of F250 ohmar99 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 33 12-28-2012 09:58 PM
Tags
1997, 73, 97, capacity, diesel, f250, f350, ford, hd, power, powerstroke, specs, stroke, tow, towing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
