V-10 spin the tires?
Mine would fairly easily, even with the 3.73's and LS, that is until the 36's went on. Now I dare not even try it for sake of destroying good tires.
The 4.56's go in next week, then I may throw the old tires on, just to melt them to the ground, especially with the ARB's.
Originally Posted by Ace!
265/75/17 tires, limited slip and 4.30...does it every time for me...two black lines. might be the pirelli scorpion tires that came stock have no grip ? ? ?
Eric
Originally Posted by hlozano
hehe. I don't even know how to powerbrake. Never had a vehicle that could do it. I've been tempted to do it in my V10 but am afraid I'll melt the rear brakes. Or worse, tear up my rear diff.
Originally Posted by ken04
with your foot on the brake pedal and the tranny in low rev the engine as high as it will go. Let off the brake just enough to move forward a tiny bit so the tires start spinning then you have to feather the brake and throttle at the same time to slow forward motion and keep the revs from going too high. After you get a good roast started shift into 2nd manually and you can keep em frying with 1/2 throttle or so. If you have a hard time getting it down throw a little bleach under your rears, plus they will make LOTS of smoke although the smell isn't quite as yummy smelling.
This is gonna get fun. Make sure you submit the carnage pics when all is said and done.
Originally Posted by Big Rig
My 02 V-10 Ex will just sqwuak the tires, but if I do a brake stand, like I did when I raced the Chebbie 8.1, it left about a 18" patch...I could smell the tire smoke.
Big Rig
Big Rig
It is possible to avoid carnage with judicious throttle application. Once the meats start spinning it's imperative to back off the throttle, even with a rev limiter no load on the engine could be bad at 5250 rpm.
Feeling a little grumpy ? Feeling low on vim and vigor ? Viagra ? NO, Enzyte ? NO, Cialus ? NO, NO, NO !! TIRE SMOKE BABY, your wife will have a BSEG, your friends will stare in awe in the locker room, you'll become a legend. All it takes is a little tire smoke once in a while. IN FACT, Car Craft has a whole section devoted to readers rides doing smoky burnouts. How about sending them some V10, SD, trailer towing, stump jumping, mud busting, 7K weighing trucks hazing the meats ?
#28
#29
I just bought a lowly 99 v-10 crew cab long box with about 97,000 on it. It is definatley not all that fast but for some reason from a dead stop if I nail it the thing will barely move and just go up in a cloud of smoke. The last patch that I laid was about 10 seconds and then I let off it feels like it would go forever or at least until it shifts. It is probably due to the open rear and skinny stock tires, but it does have the 3.73s, I wonder what it would do with 4.10s. Now if I let it roll a little than hammer it all I can get is about a 4 or 5 second screech.
