Where is the fuel pump relay/inertia switch? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 08-03-2005, 07:17 PM
hawki_peers hawki_peers is offline
hawki_peers is starting off with a positive reputation.
Hey everybody, I hope that all is well. Just wondering if you could help me with something before I drive to Minnesota from Toronto.....I am having a fuel flow problem in my 1998 MAZDA B2500, and would like to test the fuel delivery system. Please let me know (Haynes is useless as usual) where the fuel pump relay, and the inertia switch are. Also, a simple system test explanation would probably help me tonnes. It seems like when I start the truck cold, it bucks for about 30seconds, then finally breaks 3000 rpm and is able to accelarate. Also, when on the highway I have intermittent loss of power. Any suggestions would be GREATLY appreciated. THANKS!!!
Old 08-03-2005, 08:30 PM
I found the inertia switch, it seems OK. Anybody able to help me with a possible diagnostic for my problem? Thanks!
Old 08-03-2005, 11:50 PM
el conquistador el conquistador is offline
el conquistador is starting off with a positive reputation.
I would pull the codes and check the fuel pressure when the truck is having problems. you can probably get the codes pulled at autozone or the such, pick up a fuel pressure tester while you are there. Also, how many miles are on the truck and when was the last tune up?
Old 08-04-2005, 10:45 AM
pintopower8 pintopower8 is offline
pintopower8 is starting off with a positive reputation.
I had the same problem in my Ranger 2.5l it was the mass airflow sensor. Thats what I would check first. It would bounce around for a while then idle smooth back and forth. I could drive it but it would cut if I didn't keep revving it. Hope this helps
Old 08-04-2005, 10:52 AM
RangerRuss RangerRuss is offline
RangerRuss is starting off with a positive reputation.
Clean your MAF sensor real well with some non-residue electrical cleaner.
If you have not cleaned your throttle body recently, that would be a worth while exercise. Use air intake cleaner. Do not use carburetor/choke cleaner.
Keep us advised
Russ
Old 08-04-2005, 11:01 AM
1081's Avatar
1081 1081 is offline
1081 is starting off with a positive reputation.
Don't forget to change the fuel filter also if it hasn't been done in the last 15,000 miles or so. I just changed mine after 75,000 and oh what a difference it makes. At least you would have better gas flow!
<a href='http://www.smileycentral.com/?partner=ZSzeb008_ZNxmk146YYUS' target='_blank'><img src='http://smileys.smileycentral.com/cat/36/36_11_12.gif' border=0></a>
Old 08-04-2005, 10:44 PM
Wildpony2000 Wildpony2000 is offline
Wildpony2000 is starting off with a positive reputation.
Where did you find the inertia switch ? Is this the same as the emergency fuel shutoff in case of an accident ? Mine is supposed to be at the top of the carpet on the right of the hump according to my owner's manual that was still in the glovebox but I can't locate it there or at the kick panel. Is there a pic somewhere ?
Rich
Old 08-05-2005, 11:09 AM
1081's Avatar
I had three for vans and they were behind the kick panel on the passengers side. On some you can reach over the panel with your fingers and feel it, but keep in mind that this switch won't restrict fuel flow, it cuts it off in case of an accident.
Old 08-05-2005, 07:47 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
The inertia switch is the fuel cut off, just as you thought.
Thats were it should be, do you have any home spliced wires in that area?
Old 08-10-2005, 06:32 PM
It appears I do have spliced wires by the kickpanel. How many wires are we talking about and what are their colors ?
Old 08-10-2005, 08:18 PM
Ken00's Avatar
I would expect two wires, maybe brown/red or red/brown.
Old 08-10-2005, 08:47 PM
Thanks, Ken.
These are Orange with a blue stripe connected to a pink with a black stripe. There is also a multi wire connector with nothing attached to it at the top of the hump.
Rich
Old 08-11-2005, 01:12 AM
irishguyincc irishguyincc is offline
irishguyincc is starting off with a positive reputation.
Heh, I've been fighting with this kind of problem for months with my '87 Ranger. If someone has bypassed the wire that goes from the fuel relay to the inertia switch it is probably because the plug that goes into the switch is fried, as mine is. If what I described is the case on your truck try unplugging the plug from the inertia switch and see it the truck runs any better, it helped me for a while. One thing I learned is that you must leave the wire running from the relay to the end of the inertia switch plug intact. I tried splicing a line directly from the fuel relay to the line that runs from the inertia plug to the fuel pumps. The pumps had no power. When I put the line I had cut (the one from the relay to the plug) back together the pumps worked again, even with the plug unplugged from the inertia switch. Just FYI, hope that wasn't too confusing...
Old 08-11-2005, 03:26 PM
Hey Irishguyincc,
I have an 86 ranger. What color are your wires to the switch ?
Rich
Old 08-11-2005, 03:51 PM
My wires appear as follows: from fuel pump relay it's a red with green stripe, in the cab the wire from the relay to the inertia plug is orange with light blue stripe and the wire from the plug to the fuel pumps is pink with a black stripe.
Fuel inertia switch problems. LMPLLC 1999 - 2003 7.3L Power Stroke Diesel 7 02-03-2016 09:44 AM
1986 F150 no fuel pressure! 86oldschoolford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 04-30-2015 07:23 PM
Fuel issue - Help please! 3pinplug 1968-2013 Full Size Vans 6 04-29-2015 01:36 AM
86 ranger fuel system jmoore1045 Electrical Systems/Wiring 4 04-20-2015 02:38 PM
2006 Expedition - No power to Fuel Pump - Please HELP ! WhiteBeast-05-powers 1997-2006 Expedition & Navigator 18 04-27-2014 10:36 AM
Tags
2000, 2001, 2005, b2500, f150, find, ford, fuel, inertia, location, mazda, pump, ranger, relay, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
