Computer Ignition for Non-computer engines
Cheapo modules are what gave a lot of the DS ignition systems a bad name. I tried some that only lasted 6 months. Use the Motorcraft modules and mount them 1/4" off the fender with standoffs for air circulation. The stores charge big $$$ for the Motorcraft units but there are lots of them in the scrapyards that are perfectly good. Just look for the Motorcraft name.
Any luck on identifying a good knock sensor and the associated electronics??
From everthing I have read about knock sensors, they are resonant to the bore diameter. GM's 350 sensor should work on the 335 series, as both share a 4" bore, but this would need to be experimentally verified. I am lacking a recording O-scope to do the testing. If the sensor indeed works, an appropriate circuit could be designed fairly cheap (I think) that would at least trigger a knock indicator lamp, as a tuning aid.
Any suggestions on where/how to mount it?
Like I said above:
"MSD makes an Engine Knock Alert (PN 8964) but not a controller."
Jegs # 121-8964 @ $159 -WOW!!
MSD also makes a replacement for the DuraSpark module with a timing adjustment ****, too bad it is not automatic:
Jegs # 121-8778 @ $172 -WOW again!!!
http://www.jegs.com
http://www.jegs.com
shanethomas67
1997-2006 Expedition & Navigator
03-24-2008 07:50 PM
f1501988
07-20-2003 09:47 PM
