390 compression ratio...What? - Ford Truck Enthusiasts Forums
Old 08-02-2005, 11:48 PM
biz4two's Avatar
biz4two biz4two is online now
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Talking 390 compression ratio...What?
Hey guys,
How do I find the compression ratio to my 390? Tell me what I need to provide...and I will try to get it for you.
1976 F-150 4x4 390 reman. from local FORD dealership. Do have some upgrades...what do you need to know???
Thanks a bunch!!!
Old 08-03-2005, 12:07 AM
xfordman xfordman is offline
xfordman is starting off with a positive reputation.
Biz...I'd like to know the answer to that also. I have the same truck 390, same year even. I hear they are very low compression but when I do a compression test I get 175 psi. I woulda guessed that to be at least 9 to 1.
__________________
XFM...
Old 08-03-2005, 12:09 AM
Randyb12 Randyb12 is offline
Randyb12 is new and has a neutral reputation at this point.
you need to call the dealership you got it from and ask them. There are so many things that affect CR there is no way to tell you unless you remove the heads and take alot of measurements.
Old 08-03-2005, 12:16 AM
FalconStng FalconStng is offline
FalconStng is starting off with a positive reputation.
so true. Pull the head, measure the stroke, measure top of piston to deck height, cc the pistons, cc the heads, know the head gasket thickness....calculate...lot's of fun...LOL. The stock truck 390 is about 8 to 1....I've heard anything from 7.9 to 8.2.
Good Luck,
Tracy
Old 08-03-2005, 12:30 AM
biz4two's Avatar
Talking
Ok...so does the cam effect the comp ratio? Or valve springs? Intake manifold? Pushrods? Timing chain? Water pump? Carb? FelPro gaskets, etc. Truck runs great on 86 octane...in case that matters.
Let's assume my 390 was rebuilt with "stock" pistons...and the "stock" valves. After all, I did order a "stock" 390. The only mods I have done to the engine are what's listed above...
Does that help any??? I really do not want to pull the head to find this out...especially since they will need to mill it (or at least check if it needs to be milled)...always told that was a good rule of thumb to have checked.
I'm just looking for something that might be close...
Old 08-03-2005, 12:42 AM
Putt's Avatar
Putt Putt is offline
Putt is gaining momentum as a positive member of FTE.
Static compression ratio is not affected by anything you add to the outside of the engine. It is a calculated number that depends on the bore, stroke, head chamber volume, head gasket compressed volume, piston deck height, piston head style(dome, flattop, dished) and likely a couple other things I forgot!! The camshaft will affect the effective or running compression which can change the compression test results. ie. a long duration cam will cause lower readings than a short duration cam all other variables being equal.
I guess the short answer is we can't do it without those values I mentioned.
Old 08-03-2005, 12:45 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is offline
Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.Bear 45/70 has a good reputation on FTE.
Compression ratio is the difference in the cylinder's volume at Bottom Dead Center and Top Dead Center. 1000CC at Bottom Dead Center and 100cc at Top Dead Center = 1000 divided by 100 = 10 for a 10 to 1 compression ratio. The cam can change cylinder pressures, but not compression ratio.
Old 08-03-2005, 01:03 AM
Putt's Avatar
Well said Bear! I'm too long winded!!! HAHA
Old 08-03-2005, 01:17 AM
biz4two's Avatar
Talking
Quote:
So, then my 390 is completely "stock" when it comes to the compression ratio...if that is true, then what was the "stock" compression ratio of a 1976 390 truck engine? Is it as low as 8 to 1? Or 9.5 to 1?
Thanks guys! We are close...
Old 08-03-2005, 01:38 AM
Bear 45/70's Avatar
Most of the light truck 390 engines ran 8.6 to 1, while the car 390's ran about 9.5 to 1 for 2 barrel engines.
Old 08-03-2005, 12:04 PM
biz4two's Avatar
Thumbs up
BINGO!!! Thanks Bear...
390 Rebuild Help 1966F100FE352 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 10-02-2008 09:03 PM
Compression Ratio Vs Octane adamraaron FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 10-20-2007 01:46 PM
390 displacement question 390Highboy FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 11-04-2006 05:40 AM
What is are the specs and stats for the 390 FE in 1976 Fords_12345 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-25-2005 02:49 PM
390 Piston Question 76f1390 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 21 02-11-2004 01:26 AM
Tags
1976, 390, compression, engine, fe, ford, ft, ratio, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
