Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 08-02-2005, 04:08 AM
Greg99F250SDPS73's Avatar
Greg99F250SDPS73 Greg99F250SDPS73 is offline
1999 Ford F-250
Greg99F250SDPS73 is starting off with a positive reputation.
Question F250 PowerStroke Loss in Power ... Help?
I have read through the many helpful postings ... and think i have narrowed down my problem (i think) ... Here are my symptoms: truck cranks fine, idles fine, when reving up it hesitates and jumps, when putting in gear (manual) and pulling a slight hill it gets very sluggish and jumping smokes a little, when i turn it off i smell a little un burnt deisel in the exhaust pipe and surrounding air, when driving down hill and not pushing the pedal very much i can achieve speed. When on slight hill going up it slows and starts jumping and missing (i finally got it home) ... i checked the oil level, it is not completely full but not low enough that i would see to cause hpop problems. It has never stalled on me. My first thought was clogged fuel filter or water contamination. After reading through posting i think it may be the uvc harnesses.
Im just a shade tree mechanic and this is my first deisel. What would be the first thing i should check ... im broke.
F250 Powerstroke 1999 Superduty 112000 miles
Thanks
Greg
  #2 (permalink)
Old 08-02-2005, 06:07 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Site Administrator
1989 Swift DB4
IB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputationIB Tim has a superb reputation
...Welcome Greg, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
When you are down...look up...get up...and don't ever give up....
  #3 (permalink)
Old 08-02-2005, 06:48 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
The first thing that comes to mind when you describe you symptoms is torn o-rings in the IPR (injector pressure regulator). Fortunatly it's cheap to fix if you want to take it apart and replace the o-rings.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #4 (permalink)
Old 08-02-2005, 10:52 AM
1999 Ford F-250
How do i locate the IPR? Is there a document or a labeled picture? IS there anything special i have to do to take it out to replace o-rings? I think there is an IPR rebuild kit, where is the best place to get one?
__________________
1999 F250 Superduty 7.3 PSD Manual 6Speed
4WD - Short Bed - Crew Cab
COMPLETELY STOCK - ZERO MODS (would like to tap and plug fuel bowl drain)
  #5 (permalink)
Old 08-02-2005, 11:19 AM
Big Red 00 F350's Avatar
Big Red 00 F350 Big Red 00 F350 is offline
Garage is empty, add now
Big Red 00 F350 is starting off with a positive reputation.
greg99,
i just installed an o-ring kit on my 2000. It takes a 1 1/8" deep socket with deep clearance (i believe it was 2 1/2") I used a black iron deep socket since they have more clearance. I show a pic or two of where it is and what is comprised. Try and plug the hole with a rag or something after you remove until you change o-rings and replace. the kit cost me $16 or so at Intl (1825806C92 IPR Seal Kit) but you should check to see if the same p/n kit applies to your 99.
hope this helps. see the pics...
__________________
00 F350 XLT 7.3 PSD 6Speed 4x4 Supercab DRW 4.10
Banks Stinger Plus, LUK Clutch, #6637 open element, coolant filter, CCV mod
  #6 (permalink)
Old 08-02-2005, 10:25 PM
1999 Ford F-550
Big Red did you have the same problems that Greg did? Just curious.
__________________
Dan
  #7 (permalink)
Old 08-03-2005, 12:28 AM
1999 Ford F-250
I have an update ... i cranked the truck this morning to see if it still had the problem, i ran it up the road it felt like it was missing a little, steadily loss power as i tried to gain rpms .... later i replaced the fuel filter and gave it another test drive ...same thing but increasingly getting worse feels like a really bad miss ....barely got back into driveway ... i took out the IPR to see if o-rings were torn .. they seemed fine actually looked pretty clean and smooth still fitting very snug when i slid it back in. I put it back together and was just hoping that i unstuck something and it would run like a king ..... no luck it started up and i think if i had left it idleing for five seconds longer the motor would have broke off of the mounts rolled around in the yard and died.
Still no engine light, the conectors to the UVCs harnesses look ok no discoleration no hot spots, i have yet to take the VCs off ... trying to avoid it.
I have a feeling it is my HPOP or an oring or a bad fuel injector ANY IDEAS? Please.
Thanks
__________________
  #8 (permalink)
Old 08-03-2005, 12:57 AM
1999 Ford F-250
Could it be my map sensor ? I have no idea what this is but im searching through the forum for similar symptoms.
__________________
  #9 (permalink)
Old 08-03-2005, 01:09 AM
1999 Ford F-250
What are the symptoms of a bad IDM and/or relay? or PCM ? what is PCM?
__________________
  #10 (permalink)
Old 08-03-2005, 01:16 AM
1999 Ford F-250
Question
Could it be the CMP or ICP sensors .... what are the symptoms of these being faulty?
__________________
  #11 (permalink)
Old 08-03-2005, 01:33 AM
1999 Ford F-250
Question Big Red?
Big Red, HAve you figured out what your problem was? ... mine sounds real similar ... except that it never runs ok .... just real rough idleing ... i have not let it die before turning the ignition off yet but i think it would die if i left it running.
__________________
  #12 (permalink)
Old 08-03-2005, 06:56 AM
IB Tim's Avatar
Site Administrator
1989 Swift DB4
Quote:
Originally Posted by Big Red 00 F350
greg99,
Please always place an image as a link...it helps our dial-up members.
I appreciate it and so do they.
Thanks
__________________
Administrator
  #13 (permalink)
Old 08-03-2005, 04:43 PM
Todd525's Avatar
Todd525 Todd525 is offline
Todd525 is starting off with a positive reputation.
I had that problem on mine, when I took off the valve covers, I noticed that the connectors were kinda melted for the plugs, of coarse this was on my 97 dually. I dont know if the 99s are the same way from your sig or not
  #14 (permalink)
Old 08-06-2005, 12:08 AM
1999 Ford F-250
Does anyone know how i can test the 9 pin VC glowplug/injector conections for a possible ground or short without having to remove the VCs? Just a for a real quick test wit hthe multimeter... i know that this will not rule out this problem but definately can confirm it.
__________________
  #15 (permalink)
Old 08-06-2005, 02:27 AM
1999 Ford F-250
HHHHEEEELLLPPPP!!!!! Please.
I have ohm out the 9pins on each VC gasket to find .8 ohms on all eight GPs and ~3.3 to 3.4 ohms on the injectors. There is no continuity to ground on the 5 middle injectors pins and no continuity to GP pins (outer 4) on either bank. ... Did not see any problems.
I STILL NEED HELP ...... PLEASE SOMEONE With any other possible suggestions.
Is it correct when the CPS goes bad it is just bad ... no gradual two day type deterioration. My engine idled fine would not increase rpm without jumping. It only hesitated/hickuped under load (pulling hill) absolutely no power .... next day could hardly pull it out of drive ..idling was getting worse ...replaced fuel filter checked IPR o-rings .... now it want even start ... sounds like it is trying to fire .. just jerks around. There is no SES light. Ive tried to pull pending codes .. there are none.
Could it be the MAP sensor?
Could it be the innercooler boots loose?
What other things can i check before i have take to the very expensive DR/Dealer?
Thanks
Greg
__________________
Tags
73, 95, decreased, f250, good, idles, ipr, load, loss, power, powerstroke, rough, runs, sensor, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
