360/390 heads swapable?
Originally Posted by dmoore0733
i got a 68 F250 and the vin says it came with a 360 but one of the heads has the casting broken off where the exaust bolts on. can i put 390 heads on a 360 block?
thanks to all
thanks to all
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Received 1,353 Likes
on
It's my understanding 352 fe series engines with 4 barrel intakes had slightly bigger intake and exhaust valves. Also 428 head will interchange and have slightly bigger valves. Police interceptor 427 engines are the best heads. They call them Low riser heads and Hi Riser heads and are a rare find, really rare and very pricey.
Casting on block for years 67-72, will identify what engine size you really have.
http://*************.com/FEcasting-numbers.htm
How do casting numbers appear?
Most casting numbers are stamped or casted into the part itself, other have the number
FE Casting Numbers
Blocks (C1AE8015C)
390 cid
C1AE-CC1AE-GC1AE-VC2AE-BC
C2AE-BEC2AE-BRC2AE-BSC2SE
C3SE-AC3AE-KYC3ME-BC3AE-AY
C4AE-DC4AE-FC5AE-AC5AE-B
C6MEC6ME-AC8AE-AC8AE-C
C8AE-ED3TE-1D3TE-ACD3TE-HA
D4TE-ACD7TE-BA
406 cid
C2AE-JC2AE-KC2AE-VC2AE-BD
C3AE-DC3AE-V
427 cid
C3AE-MC3AE-ABC3AE-ZC4AE
C4AE-AC5AE-AC5AE-EC5AE-D
C5AE-HC6AE-BC5JE-DC6JE-B
C6AE-CC6AE-DC7AE-AC7JE-A
C8AE-AC8AE-BC8AE-H
428 cid
C6AE-AC6AE-BC6AE-FC6ME
C6ME-AC7MEC7ME-AC8ME
Crankshafts
390 cid [3.78" stroke]
2UC3AE-DC4TE-6303-B
3UC3AE-EC4TZ-A
C1AEC3AE-UC4TZ-B
C1AE-AC3AZC6AE-A
C2AE-BC4AE-BC6TE-6303-C
C2AE-DC4AE-CC6TE-6303-E
C3AEC4AE-DD2TE-6303EA
C3AE-6303-EC4AE-A
C3AE-BC4AZ-A
C3AE-CC4AZ-J
406 cid [3.78" stroke]
2UC3AE-BC4AE-C
3UC3AE-CC4AE-D
C1AEC3AE-DC4AE-A
C1AE-AC3AE-EC4AZ-A
C2AE-BC3AE-UC4AZ-J
C2AE-DC3AZC4AZ-J
C3AEC4AE-BC4TZ-A
C3AE-6303-E C4TZ-B
410 cid [3.98" stroke]
1VAC8ME-AC9ZE-CIU
C6MEC9ZE-BC9ZE-DIUB
427 cid [3.78" stroke]
2UC3AE-BC4AE-C
3UC3AE-CC4AE-D
C1AEC3AE-DC4AE-A
C1AE-AC3AE-EC4AZ-A
C2AE-BC3AE-UC4AZ-J
C2AE-DC3AZC4AZ-J
C3AEC4AE-BC4TZ-A
C3AE-6303-E C4TZ-B
428 cid [3.98" stroke]
1VAC8ME-AC9ZE-CIUC2VE
C6MEC9ZE-BC9ZE-DIUBC6ME
FE Casting Numbers
Blocks (C1AE8015C)
390 cid
D4TE-ACD7TE-BA
406 cid
C3AE-DC3AE-V
427 cid
C8AE-AC8AE-BC8AE-H
428 cid
Crankshafts
2UC3AE-DC4TE-6303-B
3UC3AE-EC4TZ-A
C1AEC3AE-UC4TZ-B
C1AE-AC3AZC6AE-A
C3AE-6303-EC4AE-A
C3AE-BC4AZ-A
C3AE-CC4AZ-J
2UC3AE-BC4AE-C
3UC3AE-CC4AE-D
C1AEC3AE-DC4AE-A
C1AE-AC3AE-EC4AZ-A
C2AE-BC3AE-UC4AZ-J
C2AE-DC3AZC4AZ-J
C3AEC4AE-BC4TZ-A
C3AE-6303-E C4TZ-B
1VAC8ME-AC9ZE-CIU
C6MEC9ZE-BC9ZE-DIUB
2UC3AE-BC4AE-C
3UC3AE-CC4AE-D
C1AEC3AE-DC4AE-A
C1AE-AC3AE-EC4AZ-A
C2AE-BC3AE-UC4AZ-J
C2AE-DC3AZC4AZ-J
C3AEC4AE-BC4TZ-A
C3AE-6303-E C4TZ-B
on
on
The 390 uses a shorter rod and shorter compression height on the piston to adjust for the longer stroke. The 360 uses a longer rod and taller piston compression height to accomplish it's compression ratio. If you move in a 390 and dont change the rods or pistons, you need super thick head gaskets to thwart damage to the internals. Now, the 390 truck motors were a lower compression unit than the car line motors. The car line used the 360 pistons with the higher compression height to bring the compression of the motor up. So, a 390 crank, 390 rods and 360 pistons are the way to go...
--Mike
--Mike
on
Years back I overhauled what I think was a 360 2 bbl from a 68 Ford Ranger(very sweet truck, wish I had it now). What I seem to remember is that the pistons were stamped 390 4V. Maybe my memory is toast but I am fairly certain that the motor was a 360. Is this possible or not? Don`t think that there is a difference in 2 or 4 bbl heads. Is this correct?
