Go Back   Ford Truck Enthusiasts Forums > Misc. > Appearance & Dress-Up
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Appearance & Dress-Up SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 08-01-2005, 04:19 PM
fordraceing_man fordraceing_man is offline
fordraceing_man is starting off with a positive reputation.
how to remove tree sap? and a few other questions
i have tree sap all over my vechical you can feel it if you run your hand across it i was wondering what is the best way to remove this? also i have read a lot about claying a vechical how often should you do this? how do you do it? and where do you get the clay? what kind of clay is best? should you wax it after you clay?
thanks,
joe
  #2 (permalink)
Old 08-01-2005, 05:51 PM
triton_2002's Avatar
triton_2002 triton_2002 is offline
triton_2002 is starting off with a positive reputation.
There are lots of tar/sap/bug removers out there, I like the ones that come in a foam because you can let it sit for a while and let it work, then wipe off. The clay bar is used to remove oxidation from the paint surface, if you run you hand over the paint after you wash it and it feels "rough" it would be a good idea to do it. You do have to wax after this.
__________________
2002 F-150 Supercab 5.4 Triton V8
Arizona Biege
  #3 (permalink)
Old 08-01-2005, 09:17 PM
RICE H8R's Avatar
RICE H8R RICE H8R is offline
RICE H8R is starting off with a positive reputation.
I've found a product called "Citra-Solve" works great for tar, and my buddy says it works great on tree sap as well. It's actually the best product for tar I've found.
__________________
RICE H8R
1995 Ford F-150 XLT 4x4
2006 Arctic Cat SnoPro 440/700efi
1998 Arctic Cat ZR 600efi Custom
2004 Yamaha Raptor 660r
  #4 (permalink)
Old 08-02-2005, 12:44 AM
460f250's Avatar
460f250 460f250 is offline
460f250 is starting off with a positive reputation.
Butter works well for dissolving pitch. Just put a little on and rub it gently around. Once it's dissolved wash the area with a little soap and water. Works great for getting it off your hands as well.
__________________
Dwayne
'79 4x4 F250 Lariat
Member Alberta / British Columbia Chapter
  #5 (permalink)
Old 08-02-2005, 07:54 AM
peppy's Avatar
peppy peppy is offline
peppy is starting off with a positive reputation.
Zippo lighter fluid......although Im sure its good for the paint too.
__________________
91 F-150 XLT SuperCab 4X4 5.0 AOD 1356 L/S Front & Back
  #6 (permalink)
Old 08-02-2005, 12:25 PM
PW01 PW01 is offline
PW01 is starting off with a positive reputation.
I use Goo-Gone, or Mirror Glaze #9 swirl remover for the really tough stuff.
__________________
2001 Ford Ranger XLT 4x4, Off Road package, SOHC 4.0 automatic, Line-X bed liner and step rails, Alpine CDA-7894, Alpine R series speakers, Undercover tonneau, Rancho RSX shocks, Clifford Matrix RS2 remote remote start/alarm, BFG All Terrain T/A ko's. 06 emblems, clear corners, Wet Okole seat covers
  #7 (permalink)
Old 08-02-2005, 03:00 PM
kontai69's Avatar
kontai69 kontai69 is offline
kontai69 is starting off with a positive reputation.
I've successfully used Mother's California Clay Bar kit to remove tree sap. You can find it at most auto parts stores.
Here is a description...
http://www.microfiber-products-online.com/07240mp.html
__________________
1999 Ford Ranger XLT Regular Cab
2.5L four
5-speed manual
  #8 (permalink)
Old 08-02-2005, 03:22 PM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
Pine-Sol not sure about the paint but it takes tree sap off ASAP. We cut down a hugh pine tree and got fresh sap all over our hands and a chain. Some goofball said use Pine-Sol. I was going to use Acetone. Well, was I wrong. The Pine-Sol did an AWESOME job!
__________________
See ya,
Eric
My Home Page
  #9 (permalink)
Old 08-03-2005, 05:56 PM
BigHazard's Avatar
BigHazard BigHazard is offline
BigHazard is starting off with a positive reputation.
A swirl removewr is used after a heavy cut compuond. I would not reccomed using a polisher on tree sap. I would do as many of you have said. Use a sap / bug remover, then clay it, then a wax. I am a detailer, I was professionally trained and have a small side business. I would stick with things that are made for the purpose intended. I would worry about hurting the paint. Just find the products and follow directions. I thin Mothers even hass a forum on that type of thing
  #10 (permalink)
Old 08-10-2005, 09:14 PM
bigexpo bigexpo is offline
bigexpo is starting off with a positive reputation.
i work at a detail shop adn if you clay the car which in your case is not needed just use some degresser or a plastic scrapper adn back to the clay part. you have to get special clay and while you clay it keep it wet with soapy water adn the clay will scratch the hel;l outta the paint so i would advise polishing it
__________________
GETTIN IT DONE IN THE EXPY
DOWN IN THE DIRTY KY
  #11 (permalink)
Old 08-12-2005, 02:57 AM
Ponyracer Ponyracer is offline
Ponyracer has a good reputation on FTE. Ponyracer has a good reputation on FTE. Ponyracer has a good reputation on FTE.
Acrysol or adhesive remover was what I found to work best.
  #12 (permalink)
Old 08-22-2005, 01:01 AM
eddie-g eddie-g is offline
eddie-g is starting off with a positive reputation.
Depending on how big the 'blob' is...I've used a small amount of gasoline on a soft cloth, or lighter fluid...seems to work. I've also used Mineral Spirits too. http://www.kleanstrip.com/ Just make sure not to rub too hard and let the area dry, wipe clean with a soft cloth and wax. Just my 2 cents.
  #13 (permalink)
Old 08-22-2005, 06:58 AM
IB Tim's Avatar
IB Tim IB Tim is offline
Administrator
IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation IB Tim has a superb reputation
...Welcome eddie-g to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Very nice first post, jumping right in and helping out~!~
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
  #14 (permalink)
Old 08-22-2005, 09:06 PM
Rick55 Rick55 is offline
Rick55 is starting off with a positive reputation.
WD 40 will disolve the sap...
  #15 (permalink)
Old 08-29-2005, 12:42 AM
SmokyOlFord's Avatar
SmokyOlFord SmokyOlFord is offline
SmokyOlFord is starting off with a positive reputation.
If you live in the right region, just wait for cold weather. Once the sap is chilled to freezing, it chips or flakes off with a soft plastic putty tool. The smear that's left is easier to finish up with one of the above methods.
Or go the other way, and park it in the sun to soften it enough to pluck off, like old bubble gum from the bottom of a school desk. If that doesn't sound appealing, maybe some shade and an ice cube on aluminum foil placed over the pitch would simulate winter for ya!
-Smoky
__________________
'85 F-150 4x4, '67 MGB, '67 Jeepster Commando, '92 Rodeo. So far.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
