Backup Light Switch - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Backup Light Switch
Old 08-01-2005, 01:00 PM
mds79 mds79 is offline
mds79 is starting off with a positive reputation.
Question Backup Light Switch
96 Ranger, 4.0L 4x4 5spd
My backup lights quit working. Bulbs are good, fuses are good. Not getting power to the line. I've traced it up to the point where it goes into the cab underneath the truck.
Is there a switch on the gear shifter that I can replace? How hard is it to get to?
Any help is greatly appreciated!!
Old 08-01-2005, 01:28 PM
jinx102672 jinx102672 is offline
jinx102672 is starting off with a positive reputation.
If it turns out to be the back-up sensor.... Not sure if a 96' is the same as a '94 but my backup sensor is on the driverside of the tranmission housing and is easily removable with an open boxend wrench (not sure which size).
Old 08-01-2005, 02:22 PM
jjanssen jjanssen is offline
jjanssen is starting off with a positive reputation.
97 Ranger, 2wD, Extended Cab, 4.0, Auto
I have a 97 ranger with no back-up lights, and discovered no b/u signal coming from the switch on the left side of the transmission. Lights come on if I hook a hot jumper to this wore. The switch is a rather significant (expensive) looking unit that has more than 10 wires connected to it.
Is this the switch that needs to be replaced. Anybody know for sure?
Old 08-01-2005, 02:37 PM
Sometimes the hardest things to figure out end up being the easiest to fix. Crawled under the truck to check the switch, and BAMO! There it was, unplugged! Apparantly when I had the clutch replaced a month ago, they forgot to plug it back in. And I was too dumb to put 2 and 2 together lol...
Thanks for the info! I always get the right answers here!
Quote:
Old 08-01-2005, 02:38 PM
Does it look like this?
Neutral Safety/Back-Up Light Switch; 12 Pin; Automatic Transmission
Averages about $40
mds79 - I'm still looking for yours.
Old 08-01-2005, 02:46 PM
Glad to hear it
Backup Light Switch: Can use alternate number {FF132} w/ Manual
Old 08-02-2005, 12:08 AM
Yup, the big one above is mine. Guess I'll bite the bullet.
Old 08-02-2005, 07:01 AM
Just be sure that that is what needs replacing first. From what you said about not getting an output signal from the unit, My guess would be the same as yours, and unfortunately the unit might have to be replaced.
Old 09-10-2008, 12:12 AM
seagull369 seagull369 is offline
seagull369 is starting off with a positive reputation.
Anybody know if the threads on the switch need to be sealed (like by wrapping it in pipe tape) when it gets installed? Not sure if transmission fluid might start dripping out if I don't. Thanks!
Old 09-10-2008, 12:38 AM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
I use those switches a lot on diff locks, and trannies. I never pipe dope them. I'll use an o-ring if the old one had it, or a copper gasket, if the old one had a copper gasket. When you remove the old one, just use the same copper gasket. Or a new o-ring. Or nothing, if nothing is there. That said, if there is nothing there, use some blue loctite on the threads.
Old 09-10-2008, 10:42 AM
Thanks for the reply. I'll look to see if it has either of those when I replace it. By the way, if anyone's in the market for one of these I found one for my truck at autozone for only $10
Need Help!! Backup Lights!!!!!! 79f250460 1973 - 1979 F-100 & Larger F-Series Trucks 37 01-23-2008 07:43 AM
Auxilliary Backup/Flood lights seahawk31 1997 - 2003 F150 10 04-30-2007 07:25 AM
a4ld backup light switch location milesad Bronco II 7 03-20-2007 10:11 AM
Trailer backup light relay atcje 1999 to 2016 Super Duty 15 03-14-2007 09:29 PM
Backup lights test? NorthernStar Aerostar 1 12-06-2004 04:42 PM
Tags
01, 1973, 1986, 2000, 97, automatic, back, backup, f100, ford, light, location, ranger, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
