Seat Interchange
  #46
Old 09-06-2012, 04:45 AM
husker77's Avatar
husker77
husker77 is offline
Originally Posted by crazy96863
Also... What about the back seat in full size broncos? I know they have the brackets for the latch in back and the pins in front... Surely these come off without to much trouble and the bench brackets can be bolted on; even if these need a couple holes drilled its not that complicated.
The rear Bronco benches are so comfy!!
Probably to narrow since they fit btw the wheel wells of a bronco.
  #47
Old 11-09-2020, 04:59 PM
Peter41's Avatar
Peter41
Peter41 is offline
I know this could be a dead thread but had a question. I have a single cab 78 F-150 with a bench seat. I found a rear bench seat out of a 1996 f-250. Will this also bolt up without any modifications?
  #48
Old 11-09-2020, 05:45 PM
phathom's Avatar
phathom
phathom is offline
No. It won't work. You can go up to 1990 for the seats. But not back to front.
  #49
Old 11-10-2020, 08:53 AM
Peter41's Avatar
Peter41
Peter41 is offline
Awesome, thank you for clearing it up! Looked like it might be close to fitting but not in the position to be doing fab work to make it fit.
  #50
Old 12-01-2021, 10:00 AM
Peter41's Avatar
Peter41
Peter41 is offline
One more question for this thread, I think it will work but double checking with the experts before buying. Front bench seat out of a 92 F-250, should bolt up without and modifications right? I have a 78 single cab.
  #51
Old 12-01-2021, 10:27 AM
jackietreehorn's Avatar
jackietreehorn
jackietreehorn is offline
Yes so long as its a plain Jane bench and you have your original rails/tracks.
some of the fancy 60-40 split benches might give you trouble.
You never know what’s been done after all these years…mine had problems because it took me a while to figure out somebody swapped in early 60’s rails.
  #52
Old 12-01-2021, 10:50 AM
Peter41's Avatar
Peter41
Peter41 is offline
Perfect! As far as I know mine has the original rails/tracks so I will roll the dice. Its the plain bench, no split. It's wired for lumbar support but I am not going to mess around with that. Just looking for something a little more comfortable and not be sitting up so high.
  #53
Old 09-14-2022, 09:31 AM
muad's Avatar
muad
muad is offline
Awesome thread, I'm glad I found it.
Hate to resurrect an old thread, but has anyone done King Ranch seats in a 78-79? We have an expedition with these seats and we love them. I found a rear bench from a 2008 F250/350 King Ranch, and I would love to swap that in my 78 F250 Ranger.
Any input is appreciated!
r8f1k
11-27-2023 01:29 AM
MountainManRobb
1999 to 2016 Super Duty
05-14-2022 12:05 PM
hgrimmett
1978 - 1996 Big Bronco
12-04-2005 10:02 PM
kedwinh
09-23-2004 09:41 AM
Charrison
03-20-2003 01:18 PM
Quick Reply: Seat Interchange
