custom hoods or scoops?
Old 08-01-2005, 12:21 PM
GubNi's Avatar
GubNi
GubNi is offline
Anyone know of a custom hood for a 73 to 79 truck? How about a scoop or cowl that can be bolted on? I hate 2 sided tape. What I really want is about 2" tall cowl that's about 24" long and at least that wide up to about 36".
Old 08-01-2005, 05:38 PM
snowman1327's Avatar
snowman1327
snowman1327 is offline
i think harwood has some hood scoops and cowl pieces that you can put on your hood, dont know if they are weldable or if you have to use 2-sided tape, try looking on the jegs or summit websites, they will have more info. or of you are able to weld and fabricate, get some sheet metal and make your own
Old 08-01-2005, 07:22 PM
JoeBlow's Avatar
JoeBlow
JoeBlow is offline
US Body has cowl induction hoods
Old 08-01-2005, 07:58 PM
highboy 74's Avatar
highboy 74
highboy 74 is offline
US body has a particular interesting hood style. It is a replica of the mustang GT 500 hood only it is made for the 73-79 truck body.
Old 08-01-2005, 08:47 PM
4starcstms's Avatar
4starcstms
4starcstms is offline
The Gt500 hood is ehhh.... well i guess it varies by individual, dont care for it myself.. They do have a nice 9" cowl induction glass hood.. thinkin about orderin a smaller, 3 or 4 incher for my 75..
Old 08-01-2005, 11:51 PM
ivanribic's Avatar
ivanribic
ivanribic is offline
I have a 5" cowl induction scoop and I like it. They are also available in 2" but I didn't care for the looks of them as you can barely see them. I will say 5-6" is as high as I'd want to go as it blocks a bit of my view already. I got an old hood from the bone yard ($30) and riveted the scoop on, and then fiberglassed it all in. It's perfectly smooth now, looks like a factory job. I have a hole cut in it and my air cleaner rises up through.
Scoop on the truck:
Here's the view from in the cab:
Old 08-02-2005, 10:01 AM
77460ford's Avatar
77460ford
77460ford is offline
Ivanribic, when you cut out the hood for the scoop how did you finish the underhood ribbing? Any pic's. Thanks.
John.
Old 08-02-2005, 06:15 PM
ivanribic's Avatar
ivanribic
I'll see if I can snap some pics tonight or tomorrow. My cut past through the ribbing to the rear of the hood. I was afraid it would weaken the hood but it didn't at all. However I didn't fill in the ribbing gaps or any of that. I'll post a pic as soon as I snap it.
Old 08-02-2005, 10:01 PM
old75F-100's Avatar
old75F-100
old75F-100 is offline
ivanribic, i like your hood thats exactly what i wanna do with mine but like u say it kinda gets in the way if you go to high.
Old 08-05-2005, 09:34 AM
haten'chevs's Avatar
haten'chevs
haten'chevs is offline
ivanribic, Where did you get your cowl induction?
Old 08-05-2005, 10:47 AM
ivanribic's Avatar
ivanribic
Alright, took me long enough but here's a picture from the underside of the hood. It's dirty but you get the idea. The center rib gets cut and some of the rear support ribbing is cut too. It would be nice to have a slightly smaller diameter air cleaner so you didn't have to chop so much but the smaller ones I found were about half that size and so were too restrictive for my engine. I don't have it on there now but I'm using a velocity stack base with a full size air cleaner on top to rise up into the scoop. It's a cool setup.
I got the scoop off ebay from a seller named mr.goodglass who's been around forever. I like his scoops because they have the center ridge which looks exactly like the ridge on the original hoods. Quality is excellent, no sagging or anything. Check out auction 7991599891, That's the same scoop I'm using. He also does them in a longer scoop but it won't fit our hoods.
Old 08-05-2005, 05:43 PM
old75F-100's Avatar
old75F-100
that just looks sweet i found a site that has cowl induction hoods for our trucks www.up22.com
Old 08-05-2005, 06:13 PM
nhswrld's Avatar
nhswrld
nhswrld is offline
thats pretty nice ivanribic...i heard from someone who tried using rivets on an induction that after a while they snapped through the scoop and just cracked all the paint and what not around the scoop...how long have you had yours done? have you ever heard of the rivets snapping through like that?
Old 08-05-2005, 06:27 PM
woody_d87's Avatar
woody_d87
woody_d87 is offline
Hey Ivan that is a real nice set-up on the hood there!! Is that the "wiring" you were talkin about to get the Cap'n runnin?
Old 08-05-2005, 07:54 PM
ivanribic's Avatar
ivanribic
The only possible way I could see rivets doing that is if they're in upside down or if the fiberglass used to make the scoop wasn't mixed right and it became brittle. Although I just put the hood on the truck that scoop has been glassed in there for almost a year now and I know Pro has a similar scoop riveted to his hood which has been on for a couple years with no problems. FWIW we bought my buddy a hood from UP22 for his GMC. It's an all fiberglass hood with 2 or 3" scoop. It looks cool but he had to do a lot of work on it and make a lot of mods to get it to fit right. Someone else in this forum bought some parts for their 73-79 truck and had a TON of problems with them. Just based in what I've seen I wouldn't recommend them but that's just me.
Woody, I have to wire up my fan relays in the bed and a few relays up front. I have a LOT of electrical stuff to play with. Going to do it in a few but it's still just over 100 degrees outside . . . not looking forward to that.
Quick Reply: custom hoods or scoops?
