Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 08-01-2005, 11:22 AM
sgtrwg's Avatar
sgtrwg sgtrwg is offline
Garage is empty, add now
sgtrwg is starting off with a positive reputation.
Question Doesn't want to start
For what ever reason my 53 F-250 has recently decided not to start right up. It used to start cold or hot with no problem what so ever. Lately I have to crank and crank to get it to start. I have replaced, points, rotor, cap & coil. Still starts hard. Dumped the sediment bowl and the it fills ok. If I dump a bit of gasoline in the carb it takes right off. Could it be time to do a rebuild on the carb? It seems to run fine once it starts.
Thanks in advance..
__________________
53 F-250
9N
1978 F-150 Custom
  #2 (permalink)
Old 08-02-2005, 11:52 AM
petejoe petejoe is offline
petejoe is starting off with a positive reputation.
Pump
I would guess it is the pump causing you the problems.
Giving you enough gas to fill the bowl but not enough pressure to meet the demand of the carburetor. After that ...rebuild the carb.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
