After-Market Guages "how to"?
I am thinking about installing some after market guages in one of the triple cluster brakets.
I have never done it and I am wondering the best way to hook them up.
Can i just tap in to the existing wiring in the dash or should I purchase new sensors for Water temp, oil pressure?
how do I hook up
1. Water Temp
2. OIL Pressure (mechanical)
3. Volt Meter
I already know how to wire for power and acc lights as I am good with hooking up stereo's and K/C lights and relays, I have just never installed guages
Can anyone provide a quick checklist?
I have a 89 302, AOD
Luke
how do I hook up
1. Water Temp
3. Volt Meter
Luke
Originally Posted by Jdenninger
your better off putting in the mechanical guages. they are more reliable. i have them in both my running bronco's.
Talk to me about ease of installation. I have no problems drilling holes but I don't want to spend an entire day installing them either LOL
Luke
Ok, Kragen had the Autometer Auto Guage triple mechanical set on sale today so I bought it.
Questions
1. Do I replace my electric oil sender with the fitting for the mechanical guage? Where exactly is it located pass or driver side? Any way to make the dash one work along side the mechanical?
2. where is the factory sender for the water temp located? radiator somewhere?
3. Best wire to tap in for accurate volt reading?
4. will removing the factory senders effect the way the engine runs? It's an 89 with a 302 so i wouldn't imagine they had all the complex computer ****e yet but want to ask before I install and my truck runs like crap
5. Where the heck fire should I mount it LOL
Thanks again
luke
Questions
Thanks again
luke
Questions
drivers side front, to get both working you would have to get a T, and theres not a lot of room
front of the block
read the instuctions they will tell you
won't affect - mine didn't
where ever you can see it easiest while driving that doesn't look like crap and that the lines will all reach
Questions
front of the block
Oil sending unit is located driver side, 10 o'clock to the oil filter (it is bell shaped on an octagon-looking piece of metal) some have suggested copper tubing as opposed to the nylon tubing. I covered my nylon tubing with wiring loom to give it added protection. As suggested by someone else you can build a "T" fitting (parts from your local home Depot) so you can the best of both worlds. Here are a few samples:
This also is located on the drivers side, front of block close to the valve cover (red wire). If you choose the wrong sending unit (there is also one located on the passenger side under your throttle body) your engine will run like crap.
I'm going to rewire mine directly to the battery...that way I know exactly what the battery is doing. Bad grounds can cause inaccurate readings.
Like I stated above only if you grab the wrong ones. These monitor engine performance and the CPU adjusts accordingly.
Since I don't smoke, I took out the ash tray and drilled the bracket (triple gauge) where that went. I think for your year you can get a triple gauge pillar pod that fits by the windshild/door like this one:
Let me know if you have anymore questions or you need more pics.
FORDMANMATT
12-31-2012 05:16 PM
