Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 07-31-2005, 03:44 PM
unluckylow's Avatar
unluckylow unluckylow is offline
Garage is empty, add now
unluckylow is starting off with a positive reputation.
EBPV removal
Hey guys I was doing a serch on the procedures to remove the EBPV but have had no luck on finding, does anyone no the site that has it. Thanks
__________________
2000 Ford F-250 SC longbed 4x4, manual trans, converted manual transfer case
Mods: Gauges, Predator programmer 80HP setting, Banks 4'' exhaust, HX crossover line, 4'' lift, 35x12.5 Nitto AT, firestone rideright airbags and custom traction bars, duel shocks up front and steering stabilizer, AIH delete, wicked wheel, SB air intake and filter.
  #2 (permalink)
Old 07-31-2005, 03:55 PM
ltfox's Avatar
ltfox ltfox is offline
ltfox is starting off with a positive reputation.
Here's a write up for the obs powerstrokes. You might be able to use it. Good luck
9497faq/tipstricks/gutebpv.php3
__________________
1994 F-250 PSD EC 4x4 5spd 4:10's, gutted ebpv, 3-4"Dp, 4"exhaust, HPX, TYMAR intake,1.0 a/r housing, 3pos TWildman chip
1996 F-250 PSD CC SB 4x4 5spd 4:10's 6oh intercooler, 3"dp and no more cat, Tymar intake & HPX, .84 a/r housing, 203* stat, 4pos Wildman chip!
  #3 (permalink)
Old 07-31-2005, 04:10 PM
HeatStroked's Avatar
HeatStroked HeatStroked is offline
HeatStroked is gaining momentum as a positive member of FTE.HeatStroked is gaining momentum as a positive member of FTE.
Unlucky,
PM me with you e-mail and ai'll send you instructions for the gutting.
You can get a Garret EBPV housing with no valve or shaft hole from an on line vendor. I gutted mine at first and over time the plug fell out.
I then went with the Garrett non-EBPV housing.
  #4 (permalink)
Old 07-31-2005, 06:34 PM
unluckylow's Avatar
I then went with the Garrett non-EBPV housing.[/quote]
I did a seach for that item and couldnt find is there a site or is it a special item.If there is a chance it could fall out I rather go with a new one where there is no chance of that.
__________________
  #5 (permalink)
Old 07-31-2005, 07:09 PM
Go HERE and scroll down to the bottom of the page for the gutless housing.
  #6 (permalink)
Old 07-31-2005, 09:24 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
That write up works great. The only thing that needs to be added to make it Superduty sepcific is the cold side CAC tube needs to be removed for easier access to the housing, and there are seven mount bolts instead of four. The valve is removed in exactly the same way.
Also, an $.88 freeze plug is a better value than a $150 housing, considering they do the exact same thing. The trick is to use a slightly oversized freeze plug (20mm works perfectly) and reinstall the snap ring over it. Mine's been that way for years, never a problem.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #7 (permalink)
Old 07-31-2005, 09:32 PM
I agree Cookie, the instructions I sent Unlucky are for the updated 2000-2003 EBPV gutting, and when the turbo is off the truck already when other goodies were installed.
In my case, a 20mm plug wasn't available and went with a 19mm, BAD. Blew it right out the exhaust after a few months.....had a mysterious air leak under the hood....hahaha.
If you check out that housing link, the housing it is actually milled out about another 1/4" - 3/8" over the stock opening.
  #8 (permalink)
Old 07-31-2005, 09:52 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Yeah, I noticed that. The alignment flange for the downpipe is gone....might make that a hassle, other than that, more flow is always better. I'm just not sure if there is $150 worth of more flow there.
I think if I needed a turbo that big to control some huge injectors I would also need that housing, but with stock injectors gutting it is working fine for me.
Is GDS using a center section out of a larger than a -38 series turbo, or do they machine the -38 for the larger shaft?
__________________
Scott
  #9 (permalink)
Old 07-31-2005, 10:10 PM
Quote:
Don't know much about their turbos other then what's on their site. I know of one PSD locally running one.
Perhaps drop GDS a line and see what they say on the shaft.
Good info. to know.
  #10 (permalink)
Old 08-02-2005, 08:52 PM
watermanh watermanh is offline
watermanh is starting off with a positive reputation.
I'm curious about this mod, what did you do with the actuator rod assembly? Do you just disconnect it and leave it hanging there? Thanks for all the great info guys, I just love tinkering with this truck! Aloha.
__________________
1997 CA. F350, 4x4, auto, C.C. 4.10's w/PML cover, Tymar intake, 3" x 4" dp, 4" exhaust, ccv mod, EBPV delete, gauges, DP Tuner 4 pos. chip, 28k trans cooler, HX crossover, BDP fuel pump, ITP boost reg, Dieselsite trans filter.
  #11 (permalink)
Old 08-02-2005, 09:01 PM
cookie88's Avatar
2001 Ford F-250
f250juggernaut
Quote:
There are several options.
If you leave it hanging it will eventually leak, but if you unthread the end and slide a piece of 3/8" tubing over the shaft and then screw the end back on it will hold it up and won't leak....as long as you remember to unplug the actuator at the base of the turbo so that it won't cycle. Another option is to cut the rod off and plug the hole. You can also replace the pedestal with one that doesn't have the actuator built in.
__________________
Scott
  #12 (permalink)
Old 01-09-2007, 01:58 PM
marvinlong's Avatar
marvinlong marvinlong is offline
marvinlong is starting off with a positive reputation.
Dealer told me that my ebpv actuator rod was broken and 1100.bucks to fix. As I understand yall here,just cut it off and plug w/20mm freeze plug? What about the sensor and pipe down below? Hope to save a bundle right here!
__________________
2009 F-150,XLT w/chrome pkg.,4x4...06 Nav.,4x4
  #13 (permalink)
Old 01-09-2007, 02:13 PM
GREGROB GREGROB is offline
GREGROB is starting off with a positive reputation.
Here's how I did mine.
http://rides.webshots.com/photo/2372912020083164471DhZeNS
I didn't use a freeze plug, just reinstalled the cap with the original snap ring. Used a threaded pipe plug and tapped the hole where the actuator rod was.
Simple and cheap.
  #14 (permalink)
Old 01-09-2007, 02:25 PM
marvinlong's Avatar
gregbob,thanks. good pics of the process. that's exactly what I needed!
__________________
  #15 (permalink)
Old 01-09-2007, 02:28 PM
sean23johnson's Avatar
sean23johnson sean23johnson is offline
sean23johnson is starting off with a positive reputation.
after you remove the valve and plug the pedestial with a 1/4npt should you hook back up the wires to the plug on the pedestial?
__________________
1999.5 F250 4X4 ECSB 7.3l ZF6, Autometer gauges, 6637, MBRP 4", ITP ported compressor housing, ITP in-tank mods, Harpooned, Riffraff FRx, Riffraff boots and inserts, PHP tunes, bellowed up-pipes, T500
Tags
2000, 2001, 73, actuator, delete, ebpv, ford, freeze, gutted, gutting, housing, mod, plug, powerstroke, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
