Homemade I-beam alignment tool?
pmasley,
I remember about 8 years ago in a Sears tire shop they had eccentrics that were inserted in the radius rod forks after the holes were inlarged to correct for caster. This would be the best way to correct caster if the truck has been lowered or raised beyond stock as well bending the beams for camber. A little machine work (lathe and Bridgeport) and you can correct your caster yourself.
.....=o&o>.....
.....=o&o>.....
I did these years ago. You need some way to anchor the frame to the floor using the two 5\8" pins that are mounted to the frame. This must be set to the correct ride height. As all factory numbers are set off this. Then chain the I-Breams down in the correct spots. Then place a jack at the end of the beam.
The two tools you need are the degree plate the front wheels set on to set toe. The second the caster\chamber degree wheel which bolts to the lug nuts.
The steering wheel must be looked into position. Test drive after job is finished.
Received 3,090 Likes
on
Yea the new ones have the eccentric ball joints. As they did away with King Pins. The upper ball joint can be turned. Then the tension bar is pushed forward or pulled backed with washers. Which was mentioned earlier. In some cases you can fix problems by replacing worn out bushings.
I have to say though. The Ford twin I-Beam is pretty tough to wear out.
