Assembly Plant Quality
Looking at a used 2002 F-250 PSD today.
From my reasearch, I have found most 2002 F-250s were built in the following plants: Allen Park, (Michigan),Kentucky Truck (Jefferson County, Ky.) and Cuautitian (Mexico)
Which plant, if anyone knows, put out the best and trucks during 2002 and did some plants have production or quality problems in 2002? Thanks, in advance, for your help and comments!
Mike
Mike
Thanks, Capt. Charlie. We just drove the truck this morning and it is very clean, well care for and nice. Has 54K on it. An Army Officer, Helcopter Pilot, is the owner and he seems miticulus and detailed in the care.
However, as posted in another section, when starting off from 0-5 MPH, there is a small "clunk". Otherwise it runs and drives like a new truck!
Any ideas? Thanks so much for the help!
Mike
Mike
I will have it checked out by a Ford mechanic. I don't know if there are codes for a small transmission glitch or clunk or not. It might be something else loose in the suspension? Who know....At any rate, the rest of the truck seems solid and there is a record of all routine fluid changes, including the transmission.
Mike
Mike
sounds like a good deal,with as many problems as these beast have with it at the 54k point and no seriouse problems it seem sthat it would be past the initial pain in the butt area
mine clunks when going in to 4x4 but thats normal, the owners manual even talks about it (atleast i hope its normal )
oh and just something i heard the northern plants usually put the anti corrosion stuff on the frame with out it having to be an option while the others dont due to where there sold or something- thats what i heard anyways i cant prove it though
My 02 F250 was from Mexico. Total POS! The paint started cracking and peeling so bad that Ford bought the truck back from me. Window molding fell off,steering wheel squeak, lots of rust on the unprotected undercarriage(it looked like the Titanic),all of this BEFORE I got to 20K miles!! My 05 replacement Kentucky truck is prefect so far in fit and finish. No VIN's starting in #3 for me thanks
Just to update, my wife and I bought the truck and are very pleased with it.
Had our local Ford dealership pull up an "Oasis Report" and the truck has only been back for warranty work twice since it was purchased new, once for a blower motor and another for a squeak in in the steering column. It was manufactured 08-09-01 and is a 2002 loaded XLT with bucket seats and rear child restraints fasterners, which was a deal clincher as we have small grandkids.
We have put a new Undercover lid and replaced the two OE batteries with two new Optimas. The OE batteries were still fine, but felt since the truck is about four years old, it would be good insurance.
Apparently it has never been used to tow with, as the towing connector is still in the original package.
The previous owner used Rotella T 15-40W and changed it between 3-4K miles. Did all his own oil and fuel filter changes, with oil and filter purchased throught the milatary commissary. Seemed like a meticulus owner, being an Army helicopter pilot just back from Iraq.
We bought some KC back up lights which I will have our dealership install, along with a KC dedicated switch to turn on the backup lights separately when hitching our travel trailer at night or other rearward lighting needs.
The tires are new Pirelli Scorpions, which have about 5K on them. We are Michelin fans, but I will leave these on for a year or two, as it would be wasteful to throw away practically new tires.
After researching the "bump" I mentioned when starting off, our Ford Master mechanic is fairly sure it is the slip joint needing special grease; not a major repair item.
Well, that is about it. Thanks so much for your help and look forward to enjoying this fine forum.
Mike
Mike
