What wire to tap into for a tach?
hmmm..
there's a pink/white wire in the dash you can use for the signal, inside the cluster.
there's also an easier to access pin #48 in the ecu.
either way it'll be innaccurate, you've gotta get a tach adapter (from somewhere like summit) for 50 bucks or so to get it really accurate
hope this helps,
rman
hope this helps,
rman
