Hawaii 01 L Recommendations
Hi everyone:
I'm a new member and I'd like to know some recommendations or comments on my 01 L that I've owned now. I'd like to know if all the modifcations that I made are safe and it would make my Lightning last longer. These are the modifications I made:
- Sillver Bullet Exhaust System
- Air Aid FIPK cone
- Superchip Microtuner
- 8 lbs motoblue lower pulley
- triple pillar gauge (EGT, BOOST, AIR/FUEL)
I'm not even sure what is my horsepower now because I have not tried it on the track yet. I'm afraid I might damage the engine. Please advise..
Also, if anyone out there who is from Hawaii I'd like to know you folks so we could do a meet somewhere like a local club..
- Air Aid FIPK cone
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
8lb pulley, I hope you have a built block. From what I've seen a 6lb'ers overspin the eaton and just create more heat, the 8 must be much worse. From what I've found the safest pulley with the best gains is a #4. I've been looking into a #4 as well as having the eaton ported but I havent had the time, because if I do it, I will have to do it right. Now if I had the time and money i'd have the rods replaced with stronger ones (and while im in there I might as well do the pistons) then hopfuly get a Whipple or a KB.
Hi, I'm a relatively new L owner too. Mine's a 2000, black, stock as a rock. I just joined this forum, and I know there's lots of good info. here. You might want to check out another forum I belong to, with lots of tech. It's for the So Cal. Lightning Owner's Club. Go to:
http://www.socalloc.com/forums/
Good luck!
Good luck!
