rear end identification
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Enjoy FTE....and
Originally Posted by LxMan1
If it came with a 5.4L, it has a 9.75" rearend. If it has a 4.2L V6 or a 4.6L v8, then it has a 8.8" rearend. All use the 8.8" in the front if 4x4.
The 9.75s and 8.8s were both found behind 5.4s, about the only sure way to tell what rear you have is to get under the truck and look at the metal tag hanging from the rear diff, although they are different in shape and may bve idnetified through that.
Ignore the top line, it gives part numbers and such, it's that bottom line that'll give you the info that you need.
355 88 XXXX
or
355 975 XXXX
It reads the ratio (the 3 is usually under the bolt head), and then the ring gear size, then a julian build date code iirc.
The front will match the rear and must be changed simultaneously if you plan on using the 4x anytime soon. The front is a reverse cut 8.8, so you can't swap in a cheap set of 8.8 gears, you have to get the right cut to them.
-Kerry
