Is Ranger 3.0 the same engine as Taurus 3.0? - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-29-2005, 03:27 PM
dfernander dfernander is offline
dfernander is starting off with a positive reputation.
Are these 2 engines the same? If so, is the difference in the fuel economy due only to the difference in the curb weights (Ranger is 255lbs heavier)?
Thanks!
Old 07-29-2005, 09:35 PM
Ken00's Avatar
Ken00 Ken00 is offline
Ken00 is gaining momentum as a positive member of FTE.Ken00 is gaining momentum as a positive member of FTE.
Welcome to FTE!!!!
The basic engine is the same, the computer programing, cam, gearing, etc, as well as the weight could contribute to a mpg difference.
Old 07-30-2005, 12:05 AM
J McGuire J McGuire is offline
J McGuire is starting off with a positive reputation.
The Taurus has more than one 3.0L The duratec is a DOHC and runs like a champ.
Old 07-30-2005, 08:20 AM
thanks! for the info
Old 07-30-2005, 05:05 PM
rebturtle's Avatar
rebturtle rebturtle is offline
rebturtle is starting off with a positive reputation.
It depends on the years & models of Ranger & Taurus you're talking about. I put a 1996 Taurus 3.0 into a 1991 Ranger and it runs like a champ. For the most part, it's the head gasket and some very minor differences in the heads. If you're swapping the entire motor (long block) then it's a non-issue. Otherwise you have to do some checking to make sure you use the right gaskets. Check this site for more info on the "Vulcan" 3.0:
http://rogueperformance.com/WelcometoFredland.html
Old 07-31-2005, 12:30 AM
racsan's Avatar
racsan racsan is offline
racsan is gaining momentum as a positive member of FTE.racsan is gaining momentum as a positive member of FTE.
only a 255 pnd difference? i would think its more than that, course theres so many differnt ranger weights. a shortbox 2wd vs a 4wd s/c would be alot. final drive gearing does alot. dont know what ratio a taurus uses, i wouldnt have less than 3.73s in a ranger chassis, and preferably 4.10s with the 3.0 remember the 3.0 makes its power higher in the rpm band than the other motors available. its a good motor, definitly a upgrade from the 2.3 but the 4.0 has more power at a lower rpm and isnt much differnt on fuel economy, unfortunatly the 3.0 and 4.0 have differnt bell housing patterns and cant be exchanged for each other without a trans change, otherwise id put my higer-milage 4.0 in the wifes lightweight taurus (just to bump up the performance a bit) and give the ranger a low-milage (only 60,000) engine. then id change my gearing to make up for the power difference. but, not possible so just a daydream. the taurus is a tire-fryer by the way.
Old 07-31-2005, 10:28 AM
FLgargoyle's Avatar
FLgargoyle FLgargoyle is offline
FLgargoyle is gaining momentum as a positive member of FTE.FLgargoyle is gaining momentum as a positive member of FTE.
I would think the biggest factor in fuel mileage would be the aerodynamics of the car versus the truck. Pick-ups are not very aerodynamic.
Old 07-31-2005, 04:51 PM
fordboy_52's Avatar
fordboy_52 fordboy_52 is offline
fordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to beholdfordboy_52 is a splendid one to behold
the gearing is way way diff as well.. that doesnt help
Matt
3.0 Engines 61_racer 3.0L V6 1 05-15-2015 06:34 PM
Adding Cruise Control?? Supercab Ranger & B-Series 2 10-23-2014 07:06 AM
2003 Ford Ranger 3.0 V6 into a 2006 Ranger? Midnitemare Engine Swaps 0 04-30-2014 11:42 PM
3.0 ta 3.0 tbolt 460 3.0L V6 3 08-04-2013 04:06 PM
3.0 in ranger 3.0 in taurus the same ??? bigjohn1895 Ranger & B-Series 9 08-28-2008 09:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
