how much freon? - Ford Truck Enthusiasts Forums
how much freon?
Old 07-29-2005, 01:07 AM
PCola PCola is offline
PCola is starting off with a positive reputation.
how much freon?
I`ve searched and searched for this info on this website and could not come up with the #`s, I need. So here goes, how many ounces does a 1989 F-250
Diesel (if that makes any difference ) a/c system use(freon). Thanks
Old 07-29-2005, 01:11 AM
ford390gashog's Avatar
ford390gashog ford390gashog is offline
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
what are you going to fill it with r12 or r134a or something else.
Old 07-29-2005, 01:18 PM
F150'89 F150'89 is offline
F150'89 is starting off with a positive reputation.
My A/C book shows 3.25 pounds for a gas or diesel and 7oz of oil for gas, 10oz of oil for diesel. If you use 134a you should use only 80% or 2.6 pounds.
Old 07-29-2005, 01:57 PM
how much freon
Thank you for your quick response. Yes I`m changing it over to 134. I`m going to roll the dice and go with the $35 changeover kit. I have friends that have used this kit with success on other vehicles. I`ve already put in 36 ounces and needed to know the #`s that you gave me. It`s working fine but could be a little cooler. I`m going to put in 6 more ounces to see if that cools it a little more. Again, thank you.
Peter
Old 07-29-2005, 02:17 PM
One thing you can also check is the fresh air door to make sure its closed all the way. There is a vacuum chamber right above the blower motor, I used a zip-tie to make sure it stays all the way closed and run my A/C on max and it gets COLD!
Old 07-29-2005, 03:37 PM
did you pull a vacuum first? never overfill it more is not btter you only want low side of 35 to 40 psi
Old 07-29-2005, 04:24 PM
jtmerritt jtmerritt is offline
jtmerritt is starting off with a positive reputation.
I think the 80% rule is a general rule of thumb and have found that on occassion 80% will cause the system to be overfilled and cooling to be inadequate. I have found the best way to charge with R-134 is to connect a set of gauges to both the high and low side of the AC system, pull a vacuum for at least a half-hour, start the engine and set the idle speed at 1200 rpm and place a fan on high blowing into the front of the condensor. Also, have a connected garden hose with a sprayer available. Place a thermometer in the center discharge vent inside the vehicle. With all windows closed place the AC on max or recirculate and the blower on high. Begin to charge the AC with R-134 and make note of the center discharge temperatures. Periodically spray the condensor to lower head pressure and to mix the R-134. Continue to charge until the center discharge temperature begins to rise. Stop. Remove just enough R-134 to get back to the lowest temperature recorded.
John
Old 08-01-2005, 09:03 AM
2tone73 2tone73 is offline
2tone73 is starting off with a positive reputation.
According to interdynamics it is 85%. Roughly 3 cans. Remember if you put to much it will blow hot air! Just my 2 cents.
How to jumpstart AC compressor on 2010 F350, for dummies proyer 6.4L Power Stroke Diesel 2 06-10-2015 02:50 PM
AC will not take freon tolmite 1999 - 2003 7.3L Power Stroke Diesel 15 06-09-2014 11:34 PM
2003 Escape low pressure freon switch 57texasranger Cooling, Heating, Ventilation & A/C 1 06-24-2013 07:58 PM
THINK I HAVE A FREON LEAK wulfman Cooling, Heating, Ventilation & A/C 3 06-12-2011 11:57 PM
96 What type of Freon ? pauldee0046 Aerostar 4 05-29-2005 02:09 AM
Tags
04, 150, 1989, 2003, 89, achow, escape, f150, f250, f350, ford, freon, need, pounds, refrigerant
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
