Power steering pump for F-250 4x4, with 460
[updated:LAST EDITED ON 08-Nov-02 AT 07:34 PM (EST)]I am putting in a 460 into my 79 Crewcab 4x4. Those of you who have put in a 460 into an F-250 or a F-350, (4x4) what did you use for the power steering pump?????????, and hoses????????????
Help!!
Kevin
Not even Cleverly Disguised as a Responsible Adult!
Help!!
Kevin
Links to articles on HOW TO do things can be found in my gallery page.
Go there and click the TOP link.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[/font]
[updated:LAST EDITED ON 08-Nov-02 AT 09:10 PM (EST)]here is a thread from a couple of days ago. all of the stuff applies to the F350 as well. F150 swap info won't help you as they have a different steering box and frame design. hawkrod
https://www.ford-trucks.com/dcforum/DCForumID91/12727.html
I've had 2 different power steering setups on my 429 in a 79 F250 4x4. First I had the set up that was used on the lincolns but it used a chevy pump and the braket was very large, heavy and look kinda funny. Then I changed it to the plastic style pump. I got the pump off a 79 302 2wd F150, but the bracket for that pump I got from L&L. This way it looks a lot better.
Jeff
Jeff
L&L Products makes a power steering bracket that lets you use your old pump, it comes withe the three bolts to mount it. Use your original hoses(or replace with new of same model) One VERY IMPORTANT thing to do with any motor swap(or any major component swap) is keep a record of exactly what you are using especially if you are "rigging" anything, it'll really suck to break down in the middle of nowhere, get a buddy on the phone, and then not be able to tell them what hose you need because you can't remember if it was original to your truck or sumthing you got at a u-pick yard off a 72 cadillac... By the way, I used the Hooker Super Comp Headers and found I had to rotate the electrical connection on my starter motor to prevent it foom grounding to the header creating a "no crank" situation. Good Luck!!
Good advice on the records.
The little 4x6 spiral notebooks are great for keeping track of what you modify so that you can keep it with the vehicle. I also make notes in the relevant sections of the Haynes or Chilton manuals I have for the vehicle also. I keep an "index" of the changes inside the front and back covers or on the "notes" pages. I don't usually make notes in factory manuals, they are to valuable to "deface".
Just some ideas from a guy that "nerdizes" everything.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
EcoboostKev
07-22-2015 07:51 PM
Kevin Ace Porter
16
07-30-2013 11:08 PM
KJKozak2
13
08-21-2002 10:37 AM
