Power steering pump for F-250 4x4, with 460 - Ford Truck Enthusiasts Forums
Old 11-08-2002, 07:33 PM
classyfish classyfish is offline
classyfish is starting off with a positive reputation.
[updated:LAST EDITED ON 08-Nov-02 AT 07:34 PM (EST)]I am putting in a 460 into my 79 Crewcab 4x4. Those of you who have put in a 460 into an F-250 or a F-350, (4x4) what did you use for the power steering pump?????????, and hoses????????????
Help!!
Kevin
Not even Cleverly Disguised as a Responsible Adult!
Old 11-08-2002, 08:18 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Links to articles on HOW TO do things can be found in my gallery page.
Go there and click the TOP link.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 11-08-2002, 08:26 PM
gray79f250 gray79f250 is offline
gray79f250 is starting off with a positive reputation.
Your best bet is a bracket and pump from a 460 lincoln etc. You may need to have a pressure hose made. In the f150s the 351 setup works but wont clear the steering box in a 250/350.
Old 11-08-2002, 09:10 PM
hawkrod hawkrod is offline
hawkrod is starting off with a positive reputation.
[updated:LAST EDITED ON 08-Nov-02 AT 09:10 PM (EST)]here is a thread from a couple of days ago. all of the stuff applies to the F350 as well. F150 swap info won't help you as they have a different steering box and frame design. hawkrod
http://www.ford-trucks.com/dcforum/DCForumID91/12727.html
Old 11-09-2002, 06:13 PM
ford429cu ford429cu is offline
ford429cu is starting off with a positive reputation.
I've had 2 different power steering setups on my 429 in a 79 F250 4x4. First I had the set up that was used on the lincolns but it used a chevy pump and the braket was very large, heavy and look kinda funny. Then I changed it to the plastic style pump. I got the pump off a 79 302 2wd F150, but the bracket for that pump I got from L&L. This way it looks a lot better.
Jeff
Old 11-15-2002, 01:05 AM
ST_Wilson ST_Wilson is offline
ST_Wilson is starting off with a positive reputation.
L&L Products makes a power steering bracket that lets you use your old pump, it comes withe the three bolts to mount it. Use your original hoses(or replace with new of same model) One VERY IMPORTANT thing to do with any motor swap(or any major component swap) is keep a record of exactly what you are using especially if you are "rigging" anything, it'll really suck to break down in the middle of nowhere, get a buddy on the phone, and then not be able to tell them what hose you need because you can't remember if it was original to your truck or sumthing you got at a u-pick yard off a 72 cadillac... By the way, I used the Hooker Super Comp Headers and found I had to rotate the electrical connection on my starter motor to prevent it foom grounding to the header creating a "no crank" situation. Good Luck!!
Old 11-15-2002, 03:28 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Good advice on the records.
The little 4x6 spiral notebooks are great for keeping track of what you modify so that you can keep it with the vehicle. I also make notes in the relevant sections of the Haynes or Chilton manuals I have for the vehicle also. I keep an "index" of the changes inside the front and back covers or on the "notes" pages. I don't usually make notes in factory manuals, they are to valuable to "deface".
Just some ideas from a guy that "nerdizes" everything.
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-15-2002, 04:27 PM
magnus magnus is offline
magnus is starting off with a positive reputation.
Like St Wilson said, L&L bracket works great. I used a L&L kit for my conversion, 400-->460, it came with the bracket which works very well and its cool gold anodized
Old 11-15-2002, 04:34 PM
theonlybull theonlybull is offline
theonlybull is starting off with a positive reputation.
Power steering pump replacement EcoboostKev 1999 - 2003 7.3L Power Stroke Diesel 4 07-22-2015 08:51 PM
2007 F250 4x4 issues krpepe 1999 to 2016 Super Duty 18 04-23-2015 04:55 PM
99 Super Duty DOA? SDArkie 1999 to 2016 Super Duty 7 11-08-2014 09:21 PM
54 f100 body on a 88 f150 4x4 frame Kevin Ace Porter 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 07-31-2013 12:08 AM
460 Stalls when I give 'er KJKozak2 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-21-2002 11:37 AM
Tags
bracket, ll, power, products, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
