Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-28-2005, 03:43 PM
racer956 racer956 is offline
Garage is empty, add now
racer956 is starting off with a positive reputation.
propane bio diesel
I a, looking into making bio diesel for my power stroke and am going to put a chip and propane injection on it will this stuff all work togather? Please help thanks
__________________
2000 F-350, LongBed, C/C
k&n intake ***. 10k mod leveling kit
35 inch open country wrapped around ultra beadlocks
  #2 (permalink)
Old 07-28-2005, 04:10 PM
arninetyes arninetyes is offline
arninetyes is starting off with a positive reputation.
Quote:
Biodiesel works just the same as petro diesel - well, almost.
Good - it lubricates better and is better for the injectors.
Bad - it gels in cold weather much more quickly.
It will work just fine with propane - well, except in cold winter.
__________________
'00 F250 4x4 StdC LB 7.3L auto
some mods, but never enough
  #3 (permalink)
Old 07-28-2005, 07:39 PM
bio diesel
cool thatnks any way to keep it from turning to gel?
__________________
  #4 (permalink)
Old 07-28-2005, 07:51 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Mix it with dino.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #5 (permalink)
Old 07-28-2005, 09:02 PM
johnny8's Avatar
johnny8 johnny8 is offline
johnny8 is starting off with a positive reputation.
or heat it... some guys in hear have systems that use engine heat to do this... their posts make for some interesting reading...
__________________
2002 F350 7.3 Auto 4x4 SD SRW SB
46637 "kwik wix" filter mod
Predator tuner
sonnax kit
walker btm
wastgate mod
dipricol gauges
tru-cool tranny cooler
superior compressor wheel
dual valve boost fooler
  #6 (permalink)
Old 07-28-2005, 09:59 PM
444dieselrod's Avatar
444dieselrod 444dieselrod is offline
1996 Ford F-250
My Garage
444dieselrod is gaining momentum as a positive member of FTE.
The heated systems also make for some VERY interesting building/fabbing.
All should work just awesome together, just make sure the chip manufacturer knows you have a propane kit, so they can back off the timing a bit in the higher boost levels.
Run Diesel Kleen to help prevent gelling. 40* and colder it might gel. I have ran reg dino oil in -20* with no problems with the Diesel Kleen, real testement to its anti gel properties.
Diesel Rod
__________________
'96 F250, Reg Cab 7.3 PSD, Auto, 4x4, XLT.
'97 F250, Ext Cab 7.3 PSD, Auto, 4x4, XLT.
'96 F250, Crew Cab 7.3 PSD, 5-SPD, 4x4, XLT.
'99 Jetta TDI, 5-SPD
'87 359 Peterbilt SHORT HOOD, 36" sleeper. 13 speed, 425 intercooled Cat.
  #7 (permalink)
Old 07-29-2005, 09:03 AM
jwbowen's Avatar
jwbowen jwbowen is offline
jwbowen is starting off with a positive reputation.
Racer,
You don't have to worry about gelling in NV. Under 40 degrees is the point at which gelling becomes a concern, and biodiesel can perform okay down into the low teens with the same additives used for petrodiesel in northern climates.
As kwik said, mixing w/ petro lowers the gel point. The complicated systems for tank heating are mostly used by people running SVO, which is much more gel-prone than biodiesel. For biodiesel, the easiest thing to do is to put a small electric heating pad (available for big trucks) on the outside of the tank next to the outlet. This can be plugged into a 12V source (battery charger) overnight and run off of the vehicle's electrical system when underway. [DON"T FORGET TO DISCONNECT THE CHARGER.] Then you can get a line heater and/or a heater/filter from Dacor to finish the job.
Honestly, there are trucks running in Aaska in the winter on pure biodiesel, using the same approaches as they use for petrodiesel to prevent gelling.
Also, the comment I have seen on other threads that biodiesel is subject to bacterial decomposition, while true, is not really relevant. Petro has the same problem, which is solved in the same way, by adding antibacterial stuff to it at the refinery.
  #8 (permalink)
Old 07-29-2005, 10:45 AM
Flash635 Flash635 is offline
Flash635 is starting off with a positive reputation.
Sounds like a plan.
See if you can have the chip made as a 2 stage so it takes advantage of the propane when you nail it.
  #9 (permalink)
Old 08-01-2005, 01:26 PM
Mark at DPPI Mark at DPPI is offline
Mark at DPPI is starting off with a positive reputation.
Racer956,
Can't tell you much on the Biodiesel, but get the MSD Digiatl propane system, the safest and most advanced out there! We have been selling them for a while and folks love it!
Mark @ DPPI
__________________
url]
  #10 (permalink)
Old 08-01-2005, 01:30 PM
edub32's Avatar
edub32 edub32 is offline
edub32 is starting off with a positive reputation.
Will the chip be fine on 100% WVO?
__________________
2004 F150 Lariat SCREW 4x4
- 2.5" Autospring Leveling Kit
  #11 (permalink)
Old 08-01-2005, 06:27 PM
1996 Ford F-250
My Garage
Yes.
Diesel Rod
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
