Outside Temp. Reset
07-27-2005, 11:20 PM
on
Outside Temp. Reset
I have a '03 F250 and the overhead console temp. is stuck at -40. How do can I reset it. Please Help!
Reason: More Information
07-28-2005, 05:01 AM
07-28-2005, 06:43 PM
on
You can try disconnecting the batttey for 10-15 min. but most likely its the temp sensor. It's under the radiator cover
07-28-2005, 06:50 PM
Thread moved to Super Duty forum.
-Matt
07-28-2005, 10:21 PM
on
Thanks I will try that. What a great site!
07-29-2005, 08:10 AM
on
After four years of reading posts about SuperDutys, that's the first one like that!
07-29-2005, 10:57 AM
On the same topic....
I thought I read somewhere on here that there was
a way to adjust the reading by +/- 4 deg or so???
Was I dreaming???
Chris..
07-30-2005, 02:35 PM
on
haven't heard of this. The reading is probably within +/- 4 deg of the actual temp.
07-30-2005, 02:51 PM
Temp Readout
If your temp readout is stuck on -40, that usually indicates an open somewhere in the circuitry or the sensor is open.
RON
08-04-2005, 10:28 PM
on
Well I tried disconnecting the battery. That did not work. Back on July 4th I was in a fender bender. I was hit on the left front side of my truck. I am thinking that the body shop did not hook the sensor back up when they replaced parts on the front end.
sgtscrounge
03-06-2014 06:37 PM
ssg510
1999 to 2016 Super Duty
13
08-05-2012 12:56 AM
chopperpilot
1997 - 2003 F150
03-22-2008 08:27 AM
amberamber
11-09-2005 06:56 PM
gunslinger67
1983 - 2012 Ranger & B-Series
09-12-2004 10:03 AM
2005 ,
ext ,
exterior ,
external ,
f150 ,
f250 ,
ford ,
reset ,
sensor ,
superduty ,
temp ,
temperature
