1978-79 F-150 4x4 Trac bar bracket... - Ford Truck Enthusiasts Forums
Old 11-12-2002, 03:58 PM
jberylecrider's Avatar
jberylecrider jberylecrider is offline
jberylecrider is starting off with a positive reputation.
Hey guys, does anyone have a picture of where their trac bar bolts to the frame rail ?? 1978-79 4x4 F-150
I need a picture of both the single shock and dual shock setups.
Can someone scan and post it here or email it to me ?
Thanks in advance!
Old 11-13-2002, 04:19 PM
theonlybull theonlybull is offline
theonlybull is starting off with a positive reputation.
Old 11-14-2002, 03:40 PM
No one can help ???
Ok, how about this, can some one atleast tell me if their trac bar mount is on the inside or outside of the frame rail ???
Thanks!
Old 11-14-2002, 05:34 PM
1ole4d's Avatar
1ole4d 1ole4d is offline
1ole4d is starting off with a positive reputation.
It's on the outside of the driver's side frame rail.
1978 F-150 flareside. Primitive by todays standards but she was a jaw dropper back then. :-staun
Old 11-14-2002, 11:59 PM
I am doing a solid Dana44 conversion on my truck and trying to find a bracket I can use for the track bar.
I want to try and stay away from making one, for fear it will not be strong enough.
I'm hopeing I can get a bracket from some other vehicle, and make it work on my truck.
Thanks again
Old 11-15-2002, 12:46 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Wander thru a scrapyard until you find a likely candidate.
Otherwise sing the custom fabricator blues... -Hehe
Thanks for using FTE!
[font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Old 11-16-2002, 10:39 PM
TKONO TKONO is offline
TKONO is starting off with a positive reputation.
I had a machine shop make me a custom trac bar and had the ends threaded so i could use large rod ends to attatch the bar without ever havint to deal with those darn bushings getting sloppy again. If you have, or can find a bracket to copy from its not hard to make. I had to make a bracket for the frame end of the trac bar because the factory bracket was too wide. you can buy the right rod end to fit the large bolt in the axle and use factory parts on the axle, makes for a really tight ride and if you go to a bigger lift, its adjustable
Old 11-17-2002, 11:54 AM
lowcountry lowcountry is offline
lowcountry is starting off with a positive reputation.
John
do you have any pics of the custom made trac bar I have been thinks of redoing mine I have to replace the bushings about every four months
Old 11-18-2002, 12:18 AM
Not at the moment, and that truck is at the tranny shop. When I get it back I will try to get a pic on here for you.
Old 11-18-2002, 12:53 PM
Thanks!
Manual to Automatic 66FordGuy 1961 - 1966 F-100 & Larger F-Series Trucks 6 06-03-2015 04:00 PM
WTB - 1978/79 Ford Power Steering pump bracket and pulley ronspolv WTB - Parts & other 2 05-11-2015 07:38 PM
Has Anybody Taken a 1978/79 F150/Bronco Steering gear and clocked the steering? Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-25-2014 11:32 AM
Did any 78 1/2 ton Ford 4x4s come with small blocks? goodwrench1 1973 - 1979 F-100 & Larger F-Series Trucks 13 01-16-2014 07:39 PM
1979 F250 6" lift pictures BuiltFordTough302 1973 - 1979 F-100 & Larger F-Series Trucks 16 06-05-2013 04:36 PM
Tags
79, bar, ford, pic, trac
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
