How to on rear drum brake shoes '97 F350 - Ford Truck Enthusiasts Forums
Old 07-27-2005, 12:52 PM
bri bri is offline
bri is starting off with a positive reputation.
Done all kinds of disk brake pads, never done drum shoes.
Anyone out there got a how to with pictures (preferred) on rear drum brake shoes for a '97 F350?
Much appreciated!!
Brian
Old 07-27-2005, 09:20 PM
bri bri is offline
Also curious of common reasons for ABS light to come on. Is it likely the sensor?
Old 07-28-2005, 11:10 AM
Hope Springs Hauler's Avatar
Hope Springs Hauler Hope Springs Hauler is offline
Hope Springs Hauler is starting off with a positive reputation.
I cannot speak intelegently about the ABS but I would check the connections of the wires.
On the Drums Though:
I have no diagrams but I can tell you this. Purchase New Hardware. This means springs and clips. I found this out about 3000 miles after I bought my 96 and it wrapped the springs around the drum.
1. Remove both wheels after placing rear end on jackstands.
2. Work both drums off. (They are separate from the hubs. If it is tight you may have to loosen the star wheel. the access is from the rear of the plate.)
3. Using the other side as a reference, begin to remove the tension springs and then the clips that go through the shoe backing plates. Take note the direction of the borrom star wheels orientation.
4. Once the shoes are off, compare the new to the old and install the new adjuster pins. they drive in from the back of the shoe.
5. Using your other side as the reference put the new shoes on with the new hardware and that side is done.
6. Repeat steps 3-5 on the other side now using the clean side and your new experience as a guide.
Other material to get wil be as follows:
2 cans brake cleaner
2 pairs of pliers
a flathead screwdriver
1 good friend to help with the new springs
absence of children for when you hit your knuckles
If you want a diagram, Advance autoparts can print one for free. They also carry the bendix brand of shoes which is the ford factory brand.
Old 07-29-2005, 01:52 AM
psdpower's Avatar
psdpower psdpower is offline
psdpower is starting off with a positive reputation.
The ABS is probably the VSS sensor on top of the rear axle. It's a $20.00 part from Ford and takes about 5 mins to change. On my 97 F250 the drum and hub where one piece, but other then that the above instructions sound right on.
Old 07-29-2005, 09:26 PM
I thought that my drum and hub were one piece until I realized that the previous owner neglected to do anything with the brakes and they had corroded together. Once I got them off, I dropped the assembly on the pavement and they popped apart. The manuals that I referenced said that they stopped the 1 piece assembly in about 1990. ???
Old 07-29-2005, 09:46 PM
psdpower's Avatar
I tried everything to get mine apart, but they were definately one piece, my buddy's 95 are seperate, so I guess it's just another one of those things where Ford couldn't make up it's mind and went back and forth between two designs.
Old 08-02-2005, 11:05 PM
bri bri is offline
Thanks guys. Other than the second person I should be set.
My pads are 3.2mm, spec says replace at 3mm. Any chance that the thinckness of the pad triggers the ABS light? I'll look at the VSS sensor.
What do you guys recommend for service manuals?
Old 08-03-2005, 02:01 PM
I would try for the HAYNES or the Ford CD manual as the chiltons I have tries to cover the 1980-1996 F150-F350 in a 1.5inch book
97 F800..lucas girling brakes ??? lostinfords Large Truck 3 04-14-2015 08:30 PM
1950 F5 brake adjustment animaldawg 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-21-2014 01:53 PM
53 f350 drums 1953f350 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-06-2011 10:27 PM
97 F350 Rear Brakes/Help??? truszip Brakes, Steering, Suspension, Tires, & Wheels 1 07-05-2007 12:01 PM
Rear brake job - Help pgw85706 Ranger & B-Series 12 03-03-2007 10:11 AM
Tags
1994fordf350reardrumbrakediagram, 1996, 97, adjusters, assembly, brake, diagram, drum, dual, f350, ford, installation, picture, rear, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
