Busted Tach
Busted Tach
The tach on the bronco I bought doesn't work. Ive searched through a lot of old posts and found a lot of information.
an old post from steve83 was pretty helpful, gave me an idea of what to look for.
I also picked up a wiring diagram
So heres my problem, how would I start to troubleshoot which is causing my tach to not work? Is there a way I can test the wires to make sure they work? Is there a way to test my tach to see if it works? Am I better off replacing the background off a small clock with a picture and numbers of a tachometer to make life easier?
There wasn't a fuse 18 but I referenced up where it would have been and found fuse 5 in its place. The rest of my instrument panel works, just the tach is busted.
Im stuck
Originally Posted by steve83
It gets its signal straight from the coil on the DG/Y wire, power thru fuse 18 on the R/Y wire, and grounds thru the Bk/DG wire in the small (4-pin) connector. Check the fuse.
Im stuck
