front axle won't engage - Ford Truck Enthusiasts Forums
Old 07-26-2005, 11:26 PM
blueoval99 blueoval99 is offline
blueoval99 is starting off with a positive reputation.
Question front axle won't engage
I've got a 99' f-150 4wd with the vacuum operated hubs at the diff. vacuum pod is mounted on a bracket that allows it to pull on an arm to engage or disengage the front axle. I got under the truck and had my wife operate the switch and it's trying to engage it but no go, any help with this out there?
Old 07-27-2005, 02:02 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi and welcome to the forum
If you help move the lever will it engage?
If not then you might have low vacuum getting to it possibly due to a cracked vacuum line etc.
If the lever moves but it still doesn't engage then you may have a shift fork problem in the diff. I've replaced quite a few of them.
If you do a search in here you should find quite a bit of info in the problem.
Old 07-27-2005, 02:28 AM
cleevesj's Avatar
cleevesj cleevesj is offline
cleevesj is starting off with a positive reputation.
Hi Blue oval, Here is a link to a simple problem I had. It shows the inside of the axle at the point of the vacuum switch. The front axles need to be turning to fully engage the front end as the gear inside the vacuum switch must slide ever to engage the differential and the passenger side axle.<a href="http://www.ford-trucks.com/forums/archive/index.php/t-379249-Help%21%2097%27%20front%20axle%20problem.">Help! 97' front axle problem.</a> This should link for you, but if not just cut and paste. let me know if you can get to it or not and I will copy the pic and send it to you.
Old 07-27-2005, 09:01 AM
axle
it won't go moving or not, i think it's the fork or the coupler itself is damaged, thank's for the info.
Old 07-27-2005, 01:33 PM
cleevesj's Avatar
These front ends come out very easy also. Just unbolt the cv shafts and there are three other bolts and the drive shaft and the center section comes out very easy. Take the front diff. cover off and the axle is held in with a c clip. Slide the axle out and then you have access to the vacuum switch. I put the gear in backwards when putting in new gears and had to pull the front end back out to flip the gear in the vacuum switch and it only took about a hour to an hour and a half and was back on the road. Good Luck!
Old 07-27-2005, 02:39 PM
lancekilgore lancekilgore is offline
lancekilgore is starting off with a positive reputation.
how often should you have to replace the gears or how often do they go out. or does it depend on how often you use the 4X4 and how much abuse you give them off road?
Lance
Old 07-27-2005, 02:49 PM
cleevesj's Avatar
I have not blown a gear yet. I have blown up a CV though(Mud Bog). Nice thing about these front ends, they are easy to work on. Not the stongest, but easy to work on. I am running 4.56 gears in mine and no troubles so far. 140,000 miles.
Front Axle 4x4 Engagement bkuuz1 Expedition & Navigator 2 09-20-2014 11:21 AM
06 F150 STX 4WD actuation issues mikecyr 2004 - 2008 F150 4 12-07-2013 07:25 PM
Auto hub issues!! boggin150 1987 - 1996 F150 & Larger F-Series Trucks 15 10-09-2009 04:09 PM
4x4 won't engage arffdog 2004 - 2008 F150 3 05-01-2008 06:31 PM
How does the 4x4 work? truckmonger1 1997 - 2003 F150 3 10-30-2007 10:21 PM
Tags
1999, 2001, 95eoploer, 99, axle, cv, diff, engage, engager, expedition, f150, ford, front, vacuum, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
