1996 door panel removal ?
anyone know of a good online walk through? i've removed all the screws, but don't want to pull too hard not knowing which way the small little tabs behind the panel face...
thx
d_ballance
bah.. a quick search on google found me this --
http://www.v8sho.com/SHO/TSB99-8-15.html
back to reading
thx
d_ballance
back to reading
i just did mine & it was easy. just insert a slot screwdriver between the panel & door frame & gently pop it loose. you will invariably lose or break some of those plastic tabs but they are cheap at the zone or o'reillys. remember after you pop it loose you will have to lift it up about an inch- a small lip that goes into the window opening. once this is done you will need to wiggle the door handle through its opening then unscrew the window controls. yes it's that easy! if i can do it then anyone can - i'm the worst at fixing things!
good luck.
good luck.
Originally Posted by Jeter 94EB302
Completed the swap in about 30 minutes for both. Went very quickly following the Ford manual. Had to cut/solder the wires because Ford uses a those clip assemblies for all electrical connections. Great music again! And only a couple broken plastic snaps.
