Removing rusty bolts
Originally Posted by andym
If you have access to a welder, you can weld a head onto the bolt. Or weld a cheap pair of vice grips onto it. Get creative.
If you can't budge it with vice grips, I don't think an easy-out will work.
WD40 is a joke. Use PB blaster or some other and better concoction.
Another possibilty would be a screw extractor, but those are fairly easy to break since they are hardened so much to point of being brittle. I think welding would be the best bet, and you can cover the paint with a layer or two aluminium foil.
grind the bolt flat center punch it and start with a very small drill bit and keep stepping up the size until you are almost to the threads. once to this point take a tap of the size your bolt is and slowly tap the hole out.drill slowly so you dont break the bit off if it catches because you cant drill the bolt.
