Flasher
Old 08-23-2000, 11:47 PM
Kenny's Avatar
Kenny
Kenny is offline
Flasher
Old 11-23-2002, 10:30 PM
greenhornet's Avatar
greenhornet
greenhornet is offline
Flasher
I've finally found the flasher for my blinkers.
Its behind my headlight switch.
Now I need to know how to get to it.
My ductwork is in the way, as long with my instrument cluster.
How do you get it out?
Old 11-23-2002, 11:32 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Flasher
Remove the screws holding on the black cover panel that goes from the right side of the radio and heater controls over to the left of the headlight switch. remove the **** from the wiper switch and pull on the headlights. If you still can't reach it, there is a mushroom head button on the rear section of the headlight switch,it is usually on the top, side or bottom, not on the very back of the switch. Push it down and the headlight switch shaft will come on out and you can completely remove the panel and reach the signal blinker.
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: Flasher
