My wife and I recently purchased an 05 Escape xlt. I noticed this afternoon that the rear differential was leaking. I plan to call the dealership this week to get them to take care of it (only 1500 miles on it).
Anyone else had any problem with the rear leaking?
i am having the same problem with my ranger, it also feeld like i am getting less power from my rear wheels if you have any idea what this mite be let me know
thanks jdog12
...Welcome jdog12, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
Ford said they would replace it and recommended rather than a tech go into it, just replace the enitre rear differential. It wasn't a bad leak but it was still a leak that shouldn't be there. Especially with less than 2k miles on it!
My mechanic recently found a rear diff. seal leak on my '02 Escape and said that I might have to replace the entire rear diff. because Ford put aluminum differentials in the Escape and they warp, so a new seal would never "seal."
Anybody know if that's accurate and, if so, whether Ford has done -- or will do -- anything about it?
Quote:
Originally Posted by MazdaRangerGuy
Not a common escape problem... you just got lucky with a defective seal or something...
Because it's so rare nobody there has probably fixed a leaking one... so they'll just replace it under warranty and every one is happy
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
