cruise control / master cylinder switch replacement?
Go to the Ford dealer and buy the new switch. The old one is located on the front top of the master cylinder and has a wire pluged into it. Unplug the wire and take a crescent wrench and turn the old one counter clockwise to get it off, than screw the new one in, dont tighten too much. The wire harness that comes with the new one plugs into the switch on one end and the other end plugs into the old plug that used to plug into the switch. The total process takes about 5 mins. and you can sleep better at night. Good Luck.
Pkupman82
54
02-04-2018 01:51 PM
spongecop
1999 to 2016 Super Duty
02-03-2018 09:43 PM
