I have an 03 Exploder, I keep getting a #3cylinder miss fire code (forgot the exact code) but that is what it is. the light comes on the after a day or so it resets. Is this attributable to the fuel cap?
Check for water in the plug hole the 4.6s are bad about that. also move the #3 coil and plug to #1 and see if the skip moves to that if it does and has o carbon track or water then change the coil and plug.
