oxygen sensor + heater not ready on scan for emissions testing
Originally Posted by gibsondan
I had an issue with my V10 in my E350 in NY with the O2 sensor not being ready. Failed emmisions with the not ready, and eventually took it to the dealership. Service tech knew immediately what was wrong - NY State scans the registration and inputs the E350 as 1-8500 pound vehicle. Soon as the tech manually set it to 8501-10000 pound (read the label on the door!) it passed inspection.
Check your failed emissions slip for weight class.
The fact that the computer reports a certain test not passed, instead of just denying that it exists in the first place
Don't bother. You have an OBDI calibration and those monitors are calibrated out.
https://www.ford-trucks.com/forums/s...rchid=13150261
Another old thread brought up from the dead. 2005.
Instead of posting a search link, which will probably go away in a few hours, look here:
https://www.ford-trucks.com/forums/8...ch-folder.html
First link in the second post.
Your truck will never pass the O2 sensor and heater tests. It doesn't bother to even try.
As to why your ScanGauge won't do anything because those tests aren't complete, that's another problem entirely.
I have the same situation with my 2001 Excursion V10 and in California. I remember a Forum that I looked at over a year ago that stated if you had certain stickers under the hood you could go the smog stations and they could or would call to have a person certify and they would pass your Excursion!
I should have printed out the Forum as they also had a Smog Station in Norco, California that did it for the guy posting or someone who Replied!
Anyone know seen or know which forum it was!
Thanks
Thanks
Aungeliquema
08-28-2019 01:49 PM
Easytime
1999 to 2016 Super Duty
06-23-2013 09:37 PM
Travistjm1
06-23-2013 06:35 PM
