Duramax vs. ?
Duramax vs. ?
Not brand bashing, just letting everyone know how my day's going.
Hey guys. All morning I have been tearing apart a 17K mile 2005 Duramax truck. Why?, you ask. Well, I'll tell you.
Crank no start is the concern.
Has fuel (to injectors), has compression, cranks good.
Has a code.....for crankshaft position sensor performance.
Go looking for electrical gremlins or a bad sensor: all checks out good.
Turns out the reluctor wheel on the front of the crankshaft spins freely on the crankshaft. Isuzu didn't loctite the bolts that hold the reluctor wheel onto the main drive gear. I guess the engineers figured that diesel engines don't vibrate.
Here's a list of what has to come off to change this small part and install new loctited bolts:
Transfer case
Transmission
Flexplate
Front differential
Oil pan
Harmonic balancer
Front cover
All ancilliary stuff that goes with the front cover
3.8 Hours into it and all that's in the frame is the rear differential and an engine without an oil pan and balancer. I still have the front cover to take off...... UGH!!! I hate warranty stuff (It only pays about 1/2 of the time it'sll actually take you to do it).
Then when I'm in there I'm supposed to change the cam drive gear and the oil pump drive gear as well as the crank gear.
Watch out for the LLY!!!
Cody
Transfer case
Transmission
Flexplate
Front differential
Oil pan
Harmonic balancer
Front cover
Cody
I'm taking my camera to work today so that I can show you what failed and how much stuff actually HAS to come out just to change it.
Then I'm going to take one special picture with all the stuff around me and "BIRDIE" and I'm going to e-mail it to "Uncle General".
It's stupid....really it is. I think it was designed by fourth-generation inbred howler monkeys on barbituates!!!
Cody
Cody
dmp437,
This IS the repair. Evidently this has happened before on a few other LLY Duramaxes. The oil pan has to come off to extract the bolts that fall out of the reluctor and also to get the front cover off. Unfortunately, the transmission and flexplate have to come off too because there are two bolts that come into the oil pan from behind through the bellhousing adapter.
WXboy,
The LB7 was the first designation of the "Duramax". There was nothing wrong with them except the injector issues they had. Basically the only differences between the 01-04.5 LB7 (VIN 1) and the 04.5-present LLY (VIN 2) are the heads (for different injectors), turbocharger (went to a variable vane style like the 6.0 Ford), and a few electronics changes.
A lot of people who owned the first-gen D-maxes and went to the new ones complain of worse mileage.....up the power and that's what happens. They do run well and I'm surprised to see that since the introduction of the Isuzu diesel, we at our dealership have yet to replace an engine.
Cody
WXboy,
Cody
warrenty time no way
cody
sounds as bad as a vw suv. they have a water cooled alternator! to change it you have to put the suv on a lift and remove the engine and trans/transfer from under it along with the sub frames on this big dolly, roll it all out from under then spend 4 hours more r and i'ing the alternator , the last one took me 3 days . warrenty time 6 hours . for get the twin turbo v10 tdi it's worse to work on. who writes these books and thinks we can do it in that time .
Man o Man Cody maybe next time they will locktite the bolts. I hope not every 2005 is like that youll be a busy man for a long time an not making much money to boot. Any pics yet of this. Sounds like a commom complaint about the 6.0. Less fuel mileage then the old 7.3. More power equals less mileage.
Originally Posted by Logical Heritic
My impression was the 6.0 was doing better on fuel than the 7.3. The only complaint I kept hearing was lack of low end grunt compared to the 7.3.
