1995 Ranger cranks no Spark - Ford Truck Enthusiasts Forums
Old 07-21-2005, 09:47 AM
mr.l mr.l is offline
mr.l is starting off with a positive reputation.
I have a 1995 Ranger with a 3.0 L that will crank but has no spark. Was running find. The other day went to start it would not run no spark at plugs.Have pos. power to the coil pack with key on but not getting the neg. pulse to coil pack when cranking motor. Had a friend try to scan the codes but his scanner kept displaying to turn on ignition even with the key on. He was using the OBD-2 under the wheel XLT 87 mentioned that he believes that plug is non functional and the codes need to be pulled from under the hood is that correct. I have replaced the crank sensor already do I did not want to clear codes before I pulled them. Have 1.5 volts at crank sensor with key on. The fuel pump runs when the key is turn on. Can it be the ignition switch or would a bad cam sersor prevent spark and how can I test it? Thanks for any help.
Old 07-21-2005, 02:40 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
Your truck has the EDIS ignition system right? That means that the camshaft postion sensor (CMP) signal would not affect spark, since in EDIS the CMP signal is only used for fuel injection timing.
Have you tried cranking the engine while backprobing the crank sensor to see if there is the proper electronic switching (on/off) going on?
Old 07-21-2005, 03:56 PM
Yes I did backprobe the crank sensor one manual said take check it on a ac scale. First I use a digital meter then tried analog. No pulse but it would come up to 1.5 volts slowly cranking the motor, so I replaced it. Have not backprobe the new sensor. Going to try that maybe I had a bad one out of the box. Based on having power to sensor I think I should see a pulse there even if the pcm is bad.
Old 07-21-2005, 10:30 PM
Back probed the new sensor still no pulse. When I check for volts I check each wire to ground and get 1.5 volts using dc seting on the meter. In my Explorer manual it said when backprobing the crank sensor use ac seting on the meter. But does not say how to connect should I connect wire to wire or a wire to ground. I used a loner scanner form Autozone tried to pull codes again. The scanner showed a connecting falt it could not connect to computer. I begining to think that my 1995 may not be truly OBD-II or my computer is bad. You would think that with volts at the sensor and the engine cranking I would get a pulse even if the computer was bad. As long as the sensor was good.
Old 07-21-2005, 10:36 PM
Rockledge's Avatar
Quote:
Your '95 is a transition year vehicle. It's OBD-II, but only a few types of code pullers will work on it. Try a search in the Ranger Forum on the subject and you will come across some posts on it.
Old 07-25-2005, 12:14 PM
Iíve noticed that my fuel pump sounds like it running when turn the key on. It does not stop after a few seconds I think the regulator is dumping fuel back to the tank. If the fuel pressure regulator was bad would this cause a no pulse condition from the pcm? Does the pcm check for fuel pressure? Is there a sending unit going to the pcm? What tells the pump to shut off?
Old 08-20-2005, 08:15 PM
Bob Ayers Bob Ayers is offline
Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.Bob Ayers has a good reputation on FTE.
The PCM does not receive any signal that tells it what the fuel pressure is.
There is a timer internal to the PCM that turns the fuel pump off, if there isn't a signal from the crankshaft position sensor. The problem could be that the contacts are stuck together in the fuel pump relay, letting the fuel pump run all the time...
Old 03-24-2013, 01:03 PM
idel0817 idel0817 is offline
idel0817 is starting off with a positive reputation.
Hi, replaced water pump on a running 1995 ranger 3.0. Now the engine cranks but no start and no spark out of coil terminals. Replaced crank sensor for possibility but still no start. Please help.
Thank you
Old 03-25-2013, 08:15 AM
My problem was that the PCM went bad. Before I replaced it I checked all of thewires going to the PCM. To make sure it was not a wiring harness issue. I don'thave the truck any more so I don't have the wiring schematic.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old 03-25-2013, 09:06 AM
1995 ranger no start
Thank you Mrl
I will check further in that rout.
4.9L no spark s10 warrior 1987 - 1996 F150 & Larger F-Series Trucks 11 09-14-2015 12:37 AM
Starting mtntop1 1987 - 1996 F150 & Larger F-Series Trucks 0 04-07-2015 09:55 AM
2001 Sport Trac - No Spark? ciara.schult Explorer, Sport Trac, Mountaineer & Aviator 7 07-27-2013 07:51 PM
Yet another no spark Blue Angel 1997 - 2003 F150 11 06-11-2013 03:46 PM
No spark when cranking until I let off the key? cb88 Electrical Systems/Wiring 38 04-04-2013 07:21 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
03, 1995, 30, 98, be, coil, cranks, diagram, escape, neg, pack, pos, ranger, spark, truck, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
