miles per gallon guage-SpaceKom - Ford Truck Enthusiasts Forums
Old 07-21-2005, 02:01 AM
randylay randylay is offline
randylay is starting off with a positive reputation.
I found a SpaceKom "miles per gallon" guage in a stack of parts that have been collected over the years. Has anyone ever heard of this? I searched the web and had no hits, whick is very uncommon for my searches. What I need is how to wire it. It has 4 wires, red white yellow & black. Thanks in advance for the help. Randy
Old 07-21-2005, 02:20 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved to electrical forum.
Old 07-21-2005, 12:26 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I can't find anything either. But I don't see how it's going to work in an automotive application without a vacuum line going to it. Most of the older miles/gallon guages used engine vacuum as a means of measuring engine load.
Old 02-17-2007, 07:45 PM
vintagefordparts vintagefordparts is offline
vintagefordparts is starting off with a positive reputation.
SpaceKom Miles Per Hour Gage
I have found the same SpaceKom Gauge (miles per gallon) with 4 wires. Which Model and Year Truck is this Used for? I can't kind any info on this either.
Old 08-09-2007, 10:14 PM
WerbyFord WerbyFord is offline
WerbyFord is starting off with a positive reputation.
Smile Spacekom wiring
I am looking for this meter too or parts for it, but I have the wiring info.
Green: Power (12v) to the readout module - turnrs on & off with ignition switch
Yellow: Power (12v) to readout module, on all the time [eg cigarette lighter]
Black: Ground
Red: To Red wire from flowsensor
White: to White from speedsensor
This was a great little meter, it reads flow thru the fuel line and speed thru the speedometer cable. Very accurate when calibrated.
Any info on where I can still get one I would appreciate. Worth every penny.
Old 08-09-2007, 10:48 PM
I have one if you'd like to drop me a line. randylay at comcast.net
Old 07-17-2009, 08:47 PM
Kodiak5er Kodiak5er is offline
Kodiak5er is starting off with a positive reputation.
Here's how to wire your SpaceKom flow meter:
Black wire of transducer & black wire of gauge to ground
Red wire of transducer to red wire of gauge
White wire of transducer to white wire of gauge
Yellow wire of gauge to positive terminal thru ignition switch
The reason I know this is because I have two of these new in the boxes with the wiring directions.
Kodiak5er
Old 07-23-2009, 08:09 PM
fmc400's Avatar
fmc400 fmc400 is offline
MSEE
fmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud offmc400 has much to be proud of
I imagine he figured it out in the 4 years since he asked the question
Old 07-23-2009, 08:22 PM
No, he hadn't figured it out because he PMd me and thanked me for the responce to his question. His words were "Thank you, you went out of your way to help".
Old 08-10-2009, 11:26 AM
Kodiak5er,
I've had 2 of these SpaceKom MPG meters in the 1970s-80s. One was a black gauge with red and black buttons. The second had chrome-looking silver buttons. Neither of them work any more.
They were pretty useful.
Do you want to part with either of yours??? I'd be interested!
thanks
Old 08-10-2009, 12:56 PM
WerbyFord,
I just bought a twin engine motoryacht that has twin V 6 3.8 L Crusaders in it and plan on mounting the two fuel gauges on the flying bridge of the boat in order to get the most economical fuel burn for any speed I'm going.
Thanks for the offer anyway.
Kodiak5er
Old 09-01-2009, 06:53 PM
jforb427's Avatar
jforb427 jforb427 is offline
jforb427 is starting off with a positive reputation.
hi newbie here, I found this thread thru the wonders of google.
I just got one of these SpaceKom Autocomp 7000A mileage computers, it was with a friend's "new" RV and had not been installed yet. I'll probably scan the instructions and the box and take pics of the parts and put them on my web page some time...just because I like doing that kind of thing...
Old 01-06-2010, 01:57 AM
chazh chazh is offline
chazh is starting off with a positive reputation.
Jforb427, would love to have any contact info you can give on the makers of the autocomp system you have. Drop me a line at chazh@bellsouth.net.
Thanks
Jayco Greyhawk Motorhome on E450 Chassis with V10 MyBrokenJeep 1999 to 2016 Super Duty 4 09-30-2012 09:22 PM
How do i put a boost guage in randy450r 1999 - 2003 7.3L Power Stroke Diesel 9 05-12-2009 12:26 PM
Gas tank capacity ttexastim 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 01-21-2009 11:51 PM
SpaceKom "miles per gallon" guage randylay 1961 - 1966 F-100 & Larger F-Series Trucks 6 07-23-2005 07:11 PM
Fuel Guage Accuracy Randy626 Excursion - King of SUVs 4 06-28-2003 01:19 PM
Tags
2009, 7000a, 89, autocomp, f250, ford, gallon, gauge, meter, miles, milespergallon, mpg, spacekom, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
