O2 Sensor code P0133 on '96 Explorer - I've got questions - Ford Truck Enthusiasts Forums
Old 07-21-2005, 12:58 AM
forddude05's Avatar
forddude05 forddude05 is offline
forddude05 is starting off with a positive reputation.
Just wondering if anyone can give me some info. My mom's '96 Explorer set a Check Engine light this afternoon, and took it into Schuck's to pull codes. What I got was a code P0133 - O2 Sensor Circuit Slow Response (Bank 1 Sensor 1). Anyone else have this happen? Are there any other tests I should do before proceeding any further? Where is this particular sensor located? This truck has the 4.0 and an automatic. Any info would be appreciated.
Thanks
Jim
Old 07-21-2005, 09:30 AM
thelonerangerxlt's Avatar
thelonerangerxlt thelonerangerxlt is offline
thelonerangerxlt is starting off with a positive reputation.
Jim, that's the passenger side sensor, nearest to the exhaust manifold. Someone suggested in another thread that removing the wheel well splash guard will make it easier to access.
Generally speaking, a slow response code indicates the O2 sensor is gettting 'lazy', and a new one will indeed solve the problem......
OBII code p0133 air1jpg 2004 - 2008 F150 2 02-19-2014 09:22 PM
Aerostar P1131 P0133 codes help Brandon50394 Aerostar 7 09-18-2012 01:43 PM
2003 f150 with code p0172, p0133 jennkent5454 1997 - 2003 F150 5 11-11-2010 02:24 PM
P0133 code 69deville 3.8 & 4.2L V6 4 01-16-2007 05:40 PM
O2 sensor locations jasmo 1997 - 2003 F150 4 06-05-2004 01:36 PM
Tags
1995, 50, bank, censor, code, exploer, explorer, ford, mountaineer, o2, oxygen, p0133, response, sensor, slow
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
