2000 Exped wont unlock form switch inside
Welcome to the site Jimbo
Maybe read this first
https://www.ford-trucks.com/forums/s...d.php?t=300691
Welcome to FTE Jimbo your question would be better asked in this forum https://www.ford-trucks.com/forums/f...y.php?f=27hope you find what you need
from what I understand there are three relays on the 00 expd they are located on the fire wall just up from the gas peddle inside . It has a cover that goes over the three relays.
My Expd is sitting down in K.C. KS and I live in Omaha Ne. I work in Fort Wayne IN (I know this sounds wierd) So when I drive my work truck through Omaha I don't have the Expd.
Well everyone heres the deal
It was the relay
The location for the lock\unlock relay's
See that prety little oval patch on the right side of your dash. Its more than just nice looking it hides the relays from you. Thats right pry that little puppy up and wa la theres some relays right there and gess what thats not them. The plate that those little fellers sit on needs removed and then wa la there they are. Good luck getting the cover off becuse its a pain.
I messed with the relays to see if this indeed was my problem and sure enough the locks worked. Replace all 3 relays for $45 just so I dont have to go in again.
It was the relay
dolphans1
1997-2006 Expedition & Navigator
06-25-2017 03:31 PM
Wren
02-03-2009 08:11 AM
liftmy250
Electrical Systems/Wiring
01-07-2007 03:59 PM
