1988 Ranger trans.
Old 07-19-2005, 10:28 PM
Justen's Avatar
Justen
Justen is offline
1988 Ranger trans.
I just bought a 1988 Ford Ranger 4cyl with a fairly new 5sp. trans. I was wondering what other rangers that trany will fit in. The motor has a snapped rod and the body is rough. I know somebody that has a ranger 4cyl that is extended cab. I would like to know if my trany would fit in that ranger (since the trany is gone). I don't know the year but it is the same body style. Thanks for any help you can give me.
Old 07-20-2005, 12:17 AM
el conquistador's Avatar
el conquistador
el conquistador is offline
you should be good if you stick with the 4 banger.
Old 07-20-2005, 05:42 AM
G2IC_Wraith's Avatar
G2IC_Wraith
G2IC_Wraith is offline
There are 2 5sp trans those Rangers could have come with. One is the Mazda 5sp w/ 1 piece trans housing. These are known to leak from the 3 shift rail plugs when they get older. The other is more common in the 4x4 4 cyl, and that is the Mitsubishi 2 piece trans housing. The bellhousing is a separate piece so it is easy to spot.
If the two are not the same then you may have to also swap the clutch, x-member, driveshaft, etc..... Basically anything that could be different. My point is, don't just pull the trans and toss the truck before you know what you need.
Old 07-20-2005, 12:18 PM
Justen's Avatar
Justen
Justen is offline
The one i have is 1 piece. Both trucks are 2wd and i think that the one with the bad trany is an '88 too. I was wondering if they used different tranys in the extended and stardard cab trucks.
Old 07-20-2005, 12:35 PM
G2IC_Wraith
The cab dimensions didn't seem to matter. Look at my Sig. Mine is a Super-cab with a Mazda 5sp. I believe the Mitsu trans came on more 4x4s than 4x2s, but I can't be sure. Those 2 trans were used in all models AT LEASED from 83'-91'. I believe the 2 piece housing of the Mitsu was so they could fit it to the 2.9L 6cyl, and the 2.3L (diff bolt patterns) that came in those years too.
Old 07-20-2005, 12:53 PM
el conquistador
the mitsu tranny only came on 4x4 models. the FM145 was used from 85-89 and the FM146 was used from 88-92. after 92 only mazdas were used on 4x4 and 4x2.
Old 07-20-2005, 01:11 PM
G2IC_Wraith
I will have to trust you if you say so. I don't remember the Haynes making any distinction. If I remember it just referred to engine displacement. You could have a 2.3L with the Mazda 5sp, or a 2.3L with the Mitsu. And 2.3L 4s came in both 4x2 & 4x4.
Old 07-20-2005, 04:05 PM
Justen's Avatar
Justen
Justen is offline
The ranger i have has a 2.0, is that the same as the 2.3?
Old 07-20-2005, 08:13 PM
el conquistador
check this site out
http://www.motivegear.com/tech_info/...nny_guide.html
scroll to middle of the page.
turns out the FM146 was used on 4x2 but had a dummy transfer case but they were built for 4x4 versions.
Old 07-21-2005, 07:54 AM
G2IC_Wraith
Justen - I am not sure about the 2.0L engine. I THINK that is the Toyota engine that had a carb and no FI. As far as what trans came with it????? Crawl under there and look for the model # tag. You said it is a 1 piece case and bellhousing that would suggest a Mazda trans. If the tag says something like E87A-FE (or similar) it is a Mazda. It really can't be a Mitsu, but anyway the codes for those were posted above by el conquistador.
el conquistador - I do remember something about this from when I replaced my trans, I just didn't have the proof. Somewhere I read about the "dummy" transfer case, and I was like...... "WHHHAAAT!" Maybe Ford was running low on supply of Mazda trans at the time????? Why else would you have a 4x2 with a transfer case?
Stealth 4x4 maybe with a secret switch.
Old 07-21-2005, 10:42 AM
Justen's Avatar
Justen
Justen is offline
It does have a carb., but why would there be a toyota engine in a ford. I understand the Mazda trans. but Toyota
The code is E97A-DA, guess thats pretty close
Old 07-21-2005, 11:32 AM
el conquistador
confirmed, you have the mazda tranny.
BSilk
03-03-2009 02:58 PM
sparkemon
01-27-2006 09:50 AM
engineguy33
11-13-2005 05:39 PM
jav409
21
10-31-2005 04:05 PM
jvcajw
1978 - 1996 Big Bronco
19
05-14-2004 05:40 AM
Quick Reply: 1988 Ranger trans.
